Any of the downloads for Attribute Assistant (AA) would be useful. The trick is to create the correct rules in your DynamicValue table and, if using generate ID functions, also add the ID columns one would like to use into the GenerateID table. The combination of AA and the two tables mentioned can be modified to work within your own environment and doesn't require your data to be completely within the LGIM as the samples have. Below are a few quick examples of the rules for the DynamicValue table with the columns separated by |:
BuildingFootprint|PARCELID|INTERSECTING_FEATURE|TaxParcels|PARCELNUM|C|True
The |C| is a value to use centroids
BuildingFootprint|BLDGID|GENERATE_ID|BuildingID|6|BFID-[seq]
The |6| will pad the numeric generated ID to 6 characters from left. The GenerateID table is used to manage your numeric sequence. You would add a record to GenerateID with the field that your method will look for, in this example the attribute is |BuildingID|. The result would be BLDGID = BFID-000001 etc.
