"Load Data" grayed out in many feature classes
3619
01-15-2014 07:43 AM
RobertThomson
Occasional Contributor II
In the feature Dataset SewerStormWater (which is where I start my migration) "load data" is grayed out and only "load XML recordset document" is available.  Shouldn't this be available?
RobertThomson
It seems that you cannot load data into a feature class if it is part of a Geometric Network.  The LGM of course with predefined networks for Storm, Sanitary and Water.  I don't see any way to turn the Geometric Network off so for now my only option is to delete it and later reinstate from a backup once loading is complete.  If anyone has a better idea let me know.
RobertThomson
RyanBernardi
I am having the same issue trying to load data under the WaterDistribution Feature Dataset in the Local Government Model.  Does anyone know how to fix this problem?  I was able to load data in other feature classes, but it seems like some are greyed out (ex. wSystemValve, wMain, etc.) I am not sure what you mean by deleting and reinstating from a backup, but if that worked for you can you please explain to me how you did that?
Thank you!
AndrewFarrar
Using the "Object Loader" in arcmap should allow you to load into a dataset with a topology, something that the Simple Data Loader will not do.
http://resources.arcgis.com/en/help/main/10.1/index.html#/Adding_the_Load_Objects_command_to_ArcMap/...
