Open/ Use Lpkx ( new layer package )
12994
11-27-2014 11:24 PM
tommykurniawan1
Hi forums,
I just create layer package file  using ArcGIS Pro 1.0 pre-release build 1566, extension with this new is .lpkx file.
Is this file could used in ArcGIS desktop non Pro , i try use it with ArcGIS 10.3 not working..
Is there any info regarding this ?
Thanks - Tommy
larryzhang
tommy,
I guess, Pro team may help to anwser.
In my understading, however, the workscopes for ArcGIS Pro are fully different from desktop ArcGIS. Certainly, we are still learning and also trying to understand the purposes why ESRI makes huge efforts for Pro.
To me,  architectures and audiences between Pro and ArcGIS desktop are also targeting differently, at least, so far. So, not surprised if we couldn't seamlessly & interactive use some things among two products.
tommykurniawan1
Larry, thanks for reply / suggestions,
I've just try to export data which created inside in ArcGIS Pro to others apps. since no options for export selected layer in context menu.
Editing data methods different than ArcGIS desktop 10.2/10.3, i things i have to wait until commercial version available also..
The ideal conditions there are options for to produce also normal export .lpk beside .lpkx
Regards - Tommy
tommykurniawan1
I found the solutions, rename the .lpkx to .7z
extract the file , that contains file geodatabase inside .7z,
and use the feature class inside file geodatabase in arcgis dekstop 10.x
