I need to open a MDB file in ArcGIS Pro
35307
22
03-15-2018 08:52 AM
WilliamVong
Hello everybody! I need to open a MDB file in ArcGIS Pro, but seems that the extension is no longer support in the Pro version, do you have any idea of how i can work with the MDB file? In some post i found that I need to use ArcCatalog and now I´m using the ArcGIS Pro trial version and there is no ArcCatalog in the Pro version.
applephx
I have this same quesiton.  I have ArcGIS Pro and nothing I can think of allows me to import or convert an mdb file into a gdb in ArcGIS
RobertBorchert
Honored Contributor
You need to import everything to a filegeodatabase
Get Outlook for iOS<https://aka.ms/o0ukef>
RobertBorchert
Honored Contributor
ArcGIS Pro does not allow for the use of Personal GeoDatabases.  (.mdb {Microsoft Database})
You will need to use ArcCatalog to create a File GeoDatabase and import your features to that.  Then you can use them in Pro.
Personally one of my larger dislikes of Pro is the inability to use .mdb databases. At the least Pro should have a TOOL for importing from an ,mdb directly into a .gdb
jungao
what's personal geodatabase?
I just want to add a table from Access database. the stupid arcgis pro (perpetual beta software) won't read it. It's not even a .mdb database.
now I have to export back and forth between personal and file gdb. Kind of a pain, but at least have the work done.
This is just ESRI's way to force everyone to pro, and making a lot of "friends" in the process.
Moulay_AnwarSounny-Slitine
https://youtu.be/VVYvztYVaPs
I did a screencast here to show you the basics of converting it, but yeah you will need a copy of ArcMap to do it. It is a copy and paste from one format geodatabase to the other.  I wish they would convert ArcMap to a 'classic' version that would be included with ArcGIS Pro install, or at least make the ArcMap lic read off of an ArcGIS Pro lic automatically.  hard to renew the lic every year on your computer when you are spending most of your time in Pro
MichaelBrandonFalk
Watched the video. Thank you!
by Anonymous User
Not applicable
ESRI - With ArcMap no longer an option for new ESRI customers - what now?  Is there a plan to support the import of old data types ESRI once championed.
JenniferHarrison1
Just wanted to mention that FME can read .mdb files, and can write Geodatabase feature classes, so that might be an option.
by Anonymous User
Not applicable
Thanks Jennifer!  I was not aware of that option.  Though I am a little disappointed that I need a $650 extension to open a file I used to work with on a basic license.
KeithAddison1
I have ArcMap, I create new gdb and copy the mdb data into the new gdb.  ArcMap can read the new gdb data fine, put when I try to load it into pro I get this:
Why can ArcMap read from the new gdb but Pro can't?  The part I copy form the mdb to the gdb is an entire feature dataset that contains many feature classes.  The mdb data is from a utility company, so we're stuck with that format until they start using gdbs, which will likely be never.
