Certain fields from attribute table not displaying when I select them using symbology graduated colours.
2070
08-13-2017 03:12 PM
IainBinning
I am using a trial version of ArcGIS Pro.  I have an attribute table which I have imported as a shp. file (contains disease rates over various intervals and regional boundaries) using the "Add data to map" function in the toolbar.  I then right click the shape file and click "symbology" using the "graduated colour." I then select the field I want to display and appropriate scale.  Some fields in my attribute display exactly as I they should.  However, I can't get for of the fields (columns) to display on my map.  Both the data from the shp. file and topographic map disappear.  I can't seem to figure out why.  Any suggestions or things to check would be much appreciated. Thanks!
DanPatterson_Retired
Duplicate post.... use 'Share' rather than duplicating post contents.
Continued here....
https://community.esri.com/thread/199827-certain-fields-from-attribute-table-not-displaying-using-ar...
