sklearn.ensemble.RandomForestClassifier as a Regression?
10789
08-11-2018 08:44 AM
HannesZiegler2
Hi, I'm attempting to use sklearn.ensemble.RandomForestClassifier as a regression, but when I run it, I get the following error regarding my dependent variable y:
ValueError: Unknown label type: 'continuous'
HannesZiegler3
Hey, I found out why. I was using sklearn.ensemble.RandomForestClassifier, which is for categorical data. Use sklearn.ensemble.RandomForestRegressor instead, which takes floating point i.e. "continuous" values.
XanderBakker
Esri Esteemed Contributor
A similar problem has been reported here: python - ValueError: Unknown label type: 'continuous' - Stack Overflow . There are some suggestions that might help. BTW, the OP on Stack Overflow provided a lot more information.
HannesZiegler3
XanderBakker
Great to hear you figured out what the problem was and thanks for posting back the result.
