Help with Moving points on to Roadways
5148
01-14-2015 08:49 AM
MichelleCouden
I have traffic stations that I need joined to or merged to Roadways so I can grab some attribute table fields into the station layer. I believe I should be using the liner referencing toolbox. But the tools I am using are not working. So, it is something I am missing in my steps. Please help. I have attached a picture of the layers.
JeffBarnett1
You could just do a spatial join.  With the data in your picture you'd be pretty sure to get the correct hwy joined to the station point.
JeffBarnett1
MichelleCouden
Well, I think the join worked this time. I think the last time I did it I started with the station file instead of the line file. Just by quick check it looks like it worked this time. Thanks for your help.
XanderBakker
Esri Esteemed Contributor
Do you only want to obtain the attributes (in that case the solution by Jeff could be sufficient, although you should check stations near intersections) or do you want to move the points towards the network?
