arctan in field calculator
9652
6
10-31-2014 02:41 AM
aTomasaLooström
Hello!
I want to calculate the slope of the roof of the house and get the result in degrees. I have the height difference between the highest and lowest points of the roof and the length of the roof in the attribute table. Have tried math.atan () but do not get it to work. I have used field calculator.
Tomas
ArnoldKuilman
Result is in radians: 0.737815 / PI *180 = 42
Solution is to divide the atan output answer by PI, and multiply by 180.
DanPatterson_Retired
show the field calculator expression... also, you do have the python parser selected? Did you go to the Results window and check the error message? and if so what was it?
aTomasaLooström
Yes I have the python parser, the expression is:
math.atan(2.5/2.75 )
I get a result but it is wrong or not i degree. The result I get is 0,737815 it should be 42.
ArnoldKuilman
aTomasaLooström
Thanks a lot!
of course atan doesn't return degrees, it needs to be converted using the math.degree method
>>> import math
>>> math.degrees(math.atan(2.5/2.75))
42.27368900609374
aTomasaLooström
Thanks a lot, my maths are quite old...
