Aggregate numbers for census tracts up to the zip code level
4224
07-06-2017 10:27 AM
C_N-L
Hi, help needed!  I need to aggregate numbers for census tracts up to the zip code level (or I would like to). The problem is, it’s not a 1:1 relationship. A census tract may overlap 1-4 zip codes. I would like to see if it’s possible in ArcGIS Online or in Desktop to do an analysis that would result in the area (or % of total area, ideally) of a census tract that is associated with each zip code. Does anyone have an idea of how to do this?
JoshuaBixby
MVP Esteemed Contributor
JoshuaBixby
I believe this will help:  How Union works—Help | ArcGIS Desktop
C_N-L
Great, Thank you!
