Site Scan Manager Questions
130
331.8K
78
The message you are trying to access is permanently deleted.
Open | It would be a nice option to be able to review the control prior to processing the entire project. If ESRI could have... by JasonHall4 Occasional Contributor 0 0 | 0 | 0 | |
Under Consideration | In the Geolocations Details section of the report delta values are given for GCPs and Checkpoints. The delta value fo... by ChrisSwigert Emerging Contributor 0 1 | 0 | 1 | |
Open | Please provide the ability to export GCPs out of a project as a CSV. This will allow those GCPs to be imported into ... by AndrewBowne Frequent Contributor 0 0 | 0 | 0 | |
Open | Would like to be able to add progress photos stills to the boundary of a survey/ crosshatch mission. To where a user ... by KDuncan Occasional Contributor 0 0 | 0 | 0 | |
Open | Create a system for organizing projects using tags or categories in Site Scan. by JedXie Emerging Contributor 1 0 | 1 | 0 | |
Open | When GCP's are auto detected, It would make tagging quicker if the webpage automatically zoomed into the circle that ... by Brandyn Occasional Contributor 0 0 | 0 | 0 | |
Open | When manually tagging GCPs. After placing the tag and pressing the "save" button an approximate 1 second zoom animati... by ChrisSwigert Emerging Contributor 1 0 | 1 | 0 | |
Needs Clarification | Adding project and mission specific data to the project and mission lists in SiteScan so that the user can see how ma... by SteveDoocy Emerging Contributor 0 1 | 0 | 1 | |
Open | I have a DJI Mavic Enterprise 3 M. This drone captures multispectral RTK quality images in tiff format. The natural... by Matt-Barrett Regular Contributor 1 0 | 1 | 0 | |
Open | Using Site Scan to overlay DXF files on a project is helpful however when I de-select certain layers of DXF and reloa... by SamMaher Emerging Contributor 2 0 | 2 | 0 | |
Open | For sites that have highly reflective white material, the default white image markers are not easily visible.The abil... by SEANJEFFERYS Occasional Contributor 2 0 | 2 | 0 | |
Open | Zooming in and out in sitescan is extremely unconfortable in my point of view. Making the transition smoother would m... by GrigoriosRousakis Occasional Contributor 1 0 | 1 | 0 | |
Open | Currently georeferencing in sitescan is based on the attachement of 2 points in the mission and in the pdf file. Havi... by GrigoriosRousakis Occasional Contributor 1 0 | 1 | 0 | |
Open | Hi! Site Scan has a very nice/neat way of sharing2D results from the 2D Viewer, and3D Mesh results from the Mesh View... by Pål_Herman_Sund Frequent Contributor 6 1 | 6 | 1 | |
Open | It would be great to have the possibility to compare several profiles elevation (from xml files) in order to follow u... by ManuelCarpintero01 Emerging Contributor 2 0 | 2 | 0 |
Idea Submission Guidelines
