Overview
The connector tool allows you to publish your processed outputs from Site Scan to ArcGIS Online or ArcGIS Enterprise. On September 30th, 2025 the existing connector in Site Scan will be updated to the 2.1 version, currently in beta. The updated connector includes an improved user interface and faster publishing times. The new version also supports publishing additional data types into ArcGIS Online, including tiled and dynamic imagery layers and Oriented Imagery Layers.
If you currently use the connector to publish data from Site Scan to ArcGIS Enterprise, or create packages in Site Scan for publishing to Enterprise using the ArcGIS Pro geoprocessing tool, you must complete the migration steps listed below before September 30th, 2025 to avoid disruptions. Once you complete the migration, enable the beta version of the connector and no further changes will be needed by or on September 30th.
At a minimum, this involves reconfiguring the existing Application item in your ArcGIS Enterprise portal. If you use the create packages option in the connector for secure publishing to your Enterprise behind a firewall, this migration also involves downloading and configuring an updated version of the geoprocessing tool. Please read further for detailed migration steps.
Note: If your organization already uses the beta connector, or if your organization only publishes to ArcGIS Online (and not to ArcGIS Enterprise), no further action is needed.
In your ArcGIS Enterprise portal
Have an admin perform these steps once for your organization:
If your ArcGIS Enterprise publishing workflow involves publishing directly from Site Scan to Enterprise (rather than creating packages then publishing from Pro), you are now finished with the migration. We recommend verifying your updated configuration:
If your publishing workflow involves creating packages, complete the steps below to update the GP tool.
Publish packages in ArcGIS Pro: Download and configure the new GP tool
Any user who intends to publish Site Scan packages from ArcGIS Pro should complete these steps.
"portal": {
"url": "<ENTER_PORTAL_URL>",
"admin": {
"username": "",
"password": "",
"appid":"<ENTER_CLIENT_ID>",
"cert_file": "",
"key_file": ""
Note: You may optionally include your username and password; if you do, it will override the credentials for the current user signed into ArcGIS Pro during publishing.
Enable the beta connector and verify your new configuration
It is highly recommended to test your updated configuration ahead of time using the connector v2.1 beta version so that there are no surprises when the switch is rolled out on September 30th.
Automating your workflow
You may also automate the publishing workflow using the batch file (browse to Batchfiles > automate.bat) included in the new GP tool download folder by using Windows Task Scheduler. By running the automation file, you do not need to manually run the GP tool in ArcGIS Pro to publish packages.
For more information on configuring the automation workflow, or more information about the Enterprise configuration in general, see the updated documentation.
If you have trouble during the migration, please contact technical support.
