Fleet management is a capability in Site Scan Manager that allows drone program managers to stay informed of their organization’s flight activities, pilots, and assets. Having an accurate record of the drone fleet’s history is important to manage the lifecycle of drones and batteries, ensure pilots are current on their certifications, and predict future hardware and personnel needs.
While Site Scan Manager automatically stores drone flights that take place in the Site Scan Flight app, new Site Scan organizations want a way to import their historical fleet management data to ensure all fleet records are current and consolidated in one location. With the Batch Import feature, new and existing Site Scan organizations can import external fleet data, so that drone program managers can have a complete view of their fleet management data and history.
Regardless of where your data originates, you can import it to Site Scan if it has the required fields.
For a smooth import process, it is important to prepare your fleet management data to match the expected fields and value formats. Start by downloading the CSV templates to preview an example:
This section provides a high-level overview of the requirements. Refer to the documentation for detailed descriptions of the required data fields and formats.
You only need one of the following fields to import aircraft or batteries. Values for each must be unique:
There are additional, optional fields that you can import described in the documentation.
Flights require the following fields:
When importing flights, it’s important to maintain a relationship between the flight, aircraft, battery, and pilot. This is possible during batch import by referencing these entities for each flight using a unique identifier. Refer to the documentation for guidance on how to prepare your data for optimal matching, and how to complete matching steps during import.
The batch import workflow consists of several steps. Follow these guidelines for best results while importing your data:
Keep in mind the following during the batch import process.
If you encounter errors during batch import, check the documentation to confirm the data is formatted correctly. If there are issues you can’t resolve, contact Esri Technical Support.
