Calibrated Network Display Error
4780
10
11-25-2019 02:29 PM
ColinSchut
I've created a calibrated network which appears to be calibrated correctly, but I can see that the routes are misaligned around the calibration points (which were created from the same source dataset). Now, this is at 1:0.01 scale so the difference is microscopic, and it doesn't seem to have an practical impacts (translate lrm to lrm had no issues) but it is visually noticeable when zoomed out further.
Is this simply a display issue due to precision limits (the points are 0.2mm apart)? By definition the routes share the centreline so I figure it must be, but if this were any other dataset I would assume they weren't perfectly coincident.
Has anyone run into this before? Is this something to be concerned about?
Red = Centreline
Orange= Network 1
Green = Network 2
calibrationpoints
CliveReece
I hear you.  I've chased this before too.  Anecdotally, I've seen slight shifts when the XY domain extent changes.  It's as if the underlying XY grid shifts.  But ultimately, it just doesn't matter if the vertices and points are still within the tolerance.
