How do we correct Esri's Waze Live Alerts?
4151
11
04-12-2019 02:36 PM
BillFox
MVP Notable Contributor
How do we correct the incident type?
The Esri popup lists it as a WEATHERHAZARD which is wrong.
The road is no longer closed and it was never a WEATHERHAZARD.
Esri_Incidents: 09760f75-856c-33ac-a7fd-07a5afae7da8
Unique Incident Identifier
Last Update
February 25, 2019
Incident Type
WEATHERHAZARD
Incident Sub Type
Road Construction
Road Type Code
Confidence Code
magvar
90
Reliability
9
Report Rating
Street Address
Gettysburg Ave
City Name
Clovis, CA
Country Code
US
Report Description
by Anonymous User
Not applicable
Hey Bill,
You can modify the pop up in your web map and hide the Type field. Looking again at your earlier posts, the data available in the ArcGIS Marketplace is a mirror of what's in the Waze Live Map. So if they match, that makes sense and the problem needs corrected on the Waze side.
As you may already know, the Waze Map Editors are also a great community to work with on this as well, and you can find a few located in California here. https://wazeopedia.waze.com/wiki/USA/California#Area_Managers
Hope that helps in the interim.
Andrew
BillFox
yep, world-wide issue
