R-ArcGIS Bridge for ArcPro - Memory Allocation Limit ?
1482
09-13-2017 04:36 PM
DavidHerries
R-Script Fails for Larger Datasets (Memory Exhausted), but succeeds when not connected to ArcPro and run natively in RStudio without the Bridge.
Error Message:  Error: Memory exhausted (limit reached?)
In troubleshooting this, we used the memory.limit() function call to display memory limit allocated for the script to run within. When testing the memory limit from RStudio we get 16000+MB (PC has 16GB RAM), but when running the same check on the memory.limt() function from within ArcPRO with R the memory limit is reading Memory.limt() = 2047MB.
Hence why it is failing as it seems to be working with a different memory limit allocation when used in conjunction with ArcPro?  Does this right or are we missing something obvious?
Platform: ArcPro 2 Latest Release
R: 3.4.1 64 bit
OS: Windows 10
Hardware: i7 16GB RAM Dell XPS 15
Just moved this to this group from the main ArcPro support discussion.
Thanks in advance
Dave
ShaunWalbridge
Dave,
I can reproduce this issue locally. Despite the 64-bit DLLs involved, the memory limit is being capped at what you'd expect for a 32-bit process (2GB). I'm looking into this issue, it looks like its a default value that is being set by R, but it isn't clear to me why that is yet. In the meanwhile as a workaround, you can add this to the top of any scripts you're working with that need more memory:
limit.mb <- as.numeric(
    gsub("TotalVisibleMemorySize=", "", gsub("\r", "",
    system('wmic OS get TotalVisibleMemorySize /Value',
    intern=TRUE)[3]))) / 1024
set.limit <- memory.limit(limit.mb)‍‍‍‍‍‍‍‍‍‍‍‍‍
That will set the memory available to R to the total memory available on the machine.
Cheers,
Shaun
ShaunWalbridge
Dave,
Cheers,
Shaun
DavidHerries
Shaun
This worked perfect and is a great work around thank you.
Cheers
Dave
