windows installation trouble
8604
23
04-20-2023 09:19 AM
Labels (3)
arcgisdev007
I am able to install QT 6.5 on Mac but I have trouble running the display-a-map on Windows to verify the installation.  Specifically, I have mingui64.  When I run the display-a-map, I got ole32.lib not found.
Thomas
arcgisdev007
thank you for your help.
i was mistakenly stating i am using 200.1.0 but i was using 200.0.0.
I have installed the 200.1.0.
currently, i am able to do the following:
1. debug in android environment with debug build
2. debug in macos environment with debug build
3. debug in ios environment with release build
I will run more test and run more arcgis sdk for qt samples.
thank you.
Thomas
JamesBallard1
@arcgisdev007that's great! Don't hesitate to reach out to the team if you hit any problems.
arcgisdev007
are there more advanced samples available?  I am new to Qt and ArcGIS development.  I am learning both Qt and ArcGIS at the same time.
Thomas
JamesBallard1
@arcgisdev007yes there are. We have many samples available on github, written in both Qt C++ and Qt QML.
https://github.com/Esri/arcgis-maps-sdk-samples-qt
