Where is 32bit linux 10.2.6 build?
3191
09-30-2015 02:00 AM
JakobGaardsted
We recently upgraded our esri app source code from 10.2.3 to 10.2.6, since 10.2.3 apparently doesn't support authentication to esri online routing servers. However, we can't find any 32bit build of the sdk for Linux at
SDK Downloads | ArcGIS for Developers
https_//developers.arcgis.com/en/downloads/
Only a 64bit build?
Is this a mistake, am I overlooking something? Some of our developers work on linux, and it's a tall order to tell them
to change their linux from 32bit to 64bit, in order to access online street routing?
Thank you in advance, Jakob Gaardsted.
EricBader
Honored Contributor
Hi Jakob,
At the 10.2.3 release of ArcGIS Runtime SDK for Qt, we deprecated Linux 32-bit support. The announcement was stated in the deprecation plan here:
http://downloads2.esri.com/support/TechArticles/W32809_DEPRECATION_PLAN_FOR_ARCGIS_10_3_and_10_2_x__...
This decision came after some extensive research and customer surveys and feedback (or lack thereof). If there are serious concerns about this from our existing user base, we want to hear from you. We apologize for any current inconvenience this is causing you.
EricBader
Honored Contributor
Hi Jakob,
