Take screenshot of MapGraphicsView (in C++)
3439
03-28-2016 01:14 PM
MaximilianSchönenberg
New Contributor II
Hello,
I want to take a screenshot of the MapGraphicsView and export it to png, jpg..
I tried this, but it returns just a grey picture:
//EsriRuntimeQt::MapGraphicsView* m_MapGraphicsView;
auto pixmap = QPixmap::grabWidget(m_MapGraphicsView);
QFile file(fileUrl.toLocalFile());
file.open(QIODevice::WriteOnly);
pixmap.save(&file, "PNG");
Is there another way of taking a screenshot?
Thanks in advance!
Best regards,
Maximilian
New Contributor II
Thank you for your answer Koushik, but it's the same result as before (see attachment).
This is what finally works for me (thanks to Norbert Thoden​):
//QVBoxLayout* m_VBox
QRect rect(m_VBox->itemAt(1)->geometry());
QMutex m(QMutex::NonRecursive);
m.lock();
m.tryLock(100);
auto pixmap = QGuiApplication::primaryScreen()->grabWindow(winId(),rect.x(), rect.y(), rect.width(), rect.height());
Best regards,
Maximilian Schönenberg
LucasDanzinger
Esri Frequent Contributor
This doesn't directly help you right now, but I just wanted to let you know that with our Quartz release, there will be a function directly on the MapView that will export it to an image.
New Contributor II
Ok, but Quartz isn't released yet. Is there another way of taking a screenshot of the MapView with 10.2.6?
KoushikHajra
You can try this.  You might want to change the size of the rectangle.  But this should work:
    QRect rect(QPoint(0, 100), QSize(400, 400)) ;
    QPixmap image = QWidget::grab(rect);
    QString path = QDir::tempPath() + QString("/testImage.png");
    bool success = image.save(path);
    qDebug() << success;
Possibly didn't work because there was no size specified maybe?
New Contributor II
m.lock();
m.tryLock(100);
Best regards,
