QT maps SDK : IOS session not persisting
1553
03-22-2023 10:05 AM
GISiste
Hello @ALL
My mobile app session under IOS doesn't persist after closing : the user needs to login every time to use the application
For my Android version, the user needs to login the first time only, then the session still available for the next times
Technique environment :
AppStudio : 5.1.80
QT : 5.15.2
ArcGIS Runtime SDK for QT : 100.11.2.3121
Does anyone have an idea about this issue
LucasDanzinger
Esri Frequent Contributor
With the Runtime API itself, the credentials are only stored in memory, so if the app is closed, the credentials will not be persisted. However, I believe AppStudio has secure storage capabilities in the AppFramework that allows you to store credential info (such as token and refresh token) between app sessions - https://developers.arcgis.com/appstudio/api-reference/qml-arcgis-appframework-securestorage-securest.... I recommend checking in on the AppStudio space if you have any questions on that.
GISiste
Thanks @LucasDanzinger for your reply. I will test that and let you informed
