QML ArcGIS Runtime API - generate a new token
6863
15
09-14-2022 06:13 AM
GISiste
Hello everyone,
I'm actually working on app mobile (doing some basics functionnalities like displaying data and searching the itineraire). The data is a simple web map with a featurelayer stored in the portal federated with the ArcGIS Server
The user can use her enterprise account to access to the portal then get the token to display the web map and the data. The token has 30 minutes to expire.
Now, I would like to generate a new token once the old one has expired without displaying the popup authentication.
I am a junior in QT and ArcGIS Runtime API for QML and any advice is the most welcomed
Thank you for the help
GISiste
Hi @DavidPuckett
Is that worked for you ?
Thanks
Regards
DavidPuckett
Setting the refreshTokenExchangeInterval on the oAuthClientInfo did not work to automatically refresh the token at the set interval.
DavidPuckett
Hmmm @LucasDanzinger this did not work. I set the refreshTokenExchangeInterval on the oAuthClientInfo to 30 but it did not work to automatically refresh the token at the set interval. I started the app and let it sit for 30 minutes and sure enough it timed out. Any other tips? Is it dependent on any other properties?
LucasDanzinger
Esri Frequent Contributor
we are looking into this still
DavidPuckett
Appreciate the update. This has turned into a potential issue for us so any further info you can provide would be much appreciated.
DavidPuckett
Following up to learn if there is more info here. I have since implemented a solution that refreshes the token via a NetworkRequest put on a Timer which works most of the time. However, if the app idles too long in the background the timer will not fire to refresh the access token and the app loses access. This is especially difficult because there is no indication to the user at all. It just doesn't work and there isn't then a way to refresh the token unless I implement a manual way to refresh, inelegant. Any word on whether the refreshTokenExchangeInterval workflow has a workaround here @LucasDanzinger ?
