Poor performance when Camera is close to Surface
826
10-11-2023 08:00 PM
Hunterm522
I've noticed that my app's performance drops dramatically (<30fps) when the user navigates the Camera close to the ground/surface. This is much more apparent on 4K monitors which both of my dev machines use. I am measuring the FPS of the entire ApplicationWindow. This can be replicated with the Display a scene sample (doesn't matter if CPP or QML). Having the camera close to the surface is important for my use case (e.g. camera represents aircraft position & orientation).
Notes:
  • Surface::setNavigationConstraint(NavigationConstraint::None)
    • I notice this does improve the performance a little but then I start seeing tile edge artifacts
  • Using a TransformationMatrixCameraController and using setClippingDistance()
    • No effect at various clipping distances
  • Don't add a Surface to the Scene
    • Resolves issue, buttery smooth 60fps...but I need the elevation Surface...
  • Playing with the atmosphere effects, lighting, etc.
    • No effect
My system specs:
  • CPU:  AMD Ryzen 9 5950X
  • GPU: Nvidia GTX 1080Ti, other dev machine has a GTX 3090
  • 64GB RAM
  • 4K monitor
  • ArcGIS Qt 200.2.0
  • Qt 6.5.2
  • Manjaro Linux
  • Nvidia driver 535.113.01
