ModelSceneSymbol: is an animated model supported?
2458
03-12-2021 01:31 AM
NorbertThoden
Hi!
I tried out the example Animate3DSymbols
(arcgis-runtime-samples-qt/ArcGISRuntimeSDKQt_CppSamples/Scenes)
I have a two question:
  1. What files type are supported? Just dae?
    The link to the supported QML-Types is broken ({https://developers.arcgis.com/qt/latest/qml/guide/symbol-types-described.htm}{Symbol types}) and i cannot find that by searching...
  2. The Bristol.dae is a static model. Are also animated models support?
    Any hints?
Thx in advance!
Norbert
MarkBaird
Hi Norbert,
As well as dae files we also support 3D Max too (.3ds)
At the moment I don't believe we have any support for animated symbols, but I will check if there is anything in the pipeline.  As you say the Bristol aircraft in the samples is a static model which I created using Blender.
We'd be interested in hearing more about your use-case for animated symbols.  I wonder if our Game Engine API developments would be of interest to you.
MarkBaird
Hi Norbert,
NorbertThoden
Hi Mark!
"but I will check if there is anything in the pipeline." That would be great 🙂
Our use-case:
In our product we offer a 2D mapView  and an 3D sceneView to display the current situation of a simulation and training facility.
To get an eye catcher and to improve the display of an detonation we evaluate the ModelSceneMarker.
You mean ArcGIS for GameEngines? Good hint, i should read more about it 🙂
Thanks a lot
MarkBaird
The architecture work we are doing for Game Engine support will certainly make this easier for us in the future.  I will certainly feed back your interesting in having animated symbols as this helps us to prioritise our development efforts.
In the meantime you could try a workaround which would be to have multiple model symbols set up in a unique value renderer.  This way you would make a crude animation by changing a feature or graphic attribute to display a different phase of a basic animation.
