Minimal offline map with gray background
1579
03-19-2025 04:55 AM
FatmaAkdemir
I need a gray background map (without tiles or tile package) on a PC without no internet. Is there a way to download such a map for offline usage? What would be the correct way, do I have to download vector tiles?
MarkBockenhauer
Yes,  there are Esri basemap for that purpose.  This one for example.   https://runtimecoretest.maps.arcgis.com/home/item.html?id=3175cf5b9e9f47f284c7b7d3c8d5b387
Here is a sample that shows how to generate an offline map.   https://developers.arcgis.com/qt/cpp/sample-code/generate-offline-map/     This sample which shows the use of overrides shows how to get the desired level of detail.  https://developers.arcgis.com/qt/cpp/sample-code/generate-offline-map-overrides/
If you don't actually need map features... just a super lightweight gray background of world extent, I created these in ArcGIS Pro that you can use.    They are just 'gray boxes' at world extent (Web Mercator WGS84 auxillary sphere) in .tpkx and .vtpk format.
https://www.arcgis.com/home/item.html?id=2d1bcf22fbb84f53ba16c9305108c4df
https://www.arcgis.com/home/item.html?id=8ef1a7377bd343e2b97f53f3d50d1a36
MarkBockenhauer
I may need a bit more information to understand what you are looking for.   For maps you can set a background color, it does not require any data.
FatmaAkdemir
Hi @MarkBockenhauer , I was asking if there is a way to download BasemapStyle::ArcGISDarkGrayBase map for offline usage, or any other basemap.
MarkBockenhauer
FatmaAkdemir
Thank you very much @MarkBockenhauer . I downloaded the tile packages you created, and I'll use them.
