Memory Leak while using picturemarkersymbol
1391
09-24-2023 11:56 PM
TASL_Virendra
I am trying to load the image at runtime by calling the function_under_test() and as well add a picture marker symbol every time ,this has resulted in memory leak and when we try to clear it using the api scvImageGraphiOverLay->graphics()->clear(); still i have memory leaks .
void function_under_test(){
QByteArray data;
if(!file.open(QIODevice::ReadOnly))
return;
else
data=file.readAll();
file.close();
const unsigned char* lpchar = reinterpret_cast<const unsigned char *>(data.constData());
// Point pt1(airCraftPoint);
QImage testImg(lpchar, 1080, 1080, QImage::Format_RGB888);
scvImageSymbol = new PictureMarkerSymbol(testImg, this);
scvImageSymbol->setOpacity(0.5);scvImagetGraphic->setSymbol(scvImageSymbol);
scvImageGraphiOverLay->graphics()->append(scvImagetGraphic);
How to resolve memory leak issue related to picturemarkersymbol.
LucasDanzinger
Esri Frequent Contributor
LucasDanzinger
