Mapview not displaying in Qt 6.2.4 during stackview navigation
2067
05-16-2023 11:18 AM
Labels (3)
TasawarAhmad
I am able to load a map using "Display a map" tutorial.
Now as per my requirement, I want to load this map in QT StackView.
However, when I navigate from my mainMenu to mapScreen using stackview, then map is not loading at all.
Here is my code for your review pls.
Main.cpp
int main(){
 qDebug() << "Initializing application";
#if defined(Q_OS_LINUX) && !defined(Q_OS_ANDROID)
    // Linux requires 3.2 OpenGL Context
    // in order to instance 3D symbols
    QSurfaceFormat fmt = QSurfaceFormat::defaultFormat();
    fmt.setVersion(3, 2);
    QSurfaceFormat::setDefaultFormat(fmt);
#endif
#if defined(Q_OS_IOS)
    Q_IMPORT_PLUGIN(ArcGISRuntimePlugin);
#endif
    QApplication app(argc, argv);  //QGuiApplication
    const QString apiKey = QString("MY_PRIVATE_KEY");
    if (apiKey.isEmpty())
        qWarning() << "Use of Esri location services, including basemaps, requires" <<
                      "you to authenticate with an ArcGIS identity or set the API Key property.";
    else
       QCoreApplication::instance()->setProperty("Esri.ArcGISRuntime.apiKey", apiKey);
    // Intialize application window
    QQmlApplicationEngine appEngine;
    appEngine.addImportPath(QDir(QCoreApplication::applicationDirPath()).filePath("qml"));
#ifdef ARCGIS_RUNTIME_IMPORT_PATH_2
    appEngine.addImportPath(ARCGIS_RUNTIME_IMPORT_PATH_2);
#endif
     mainViewModel=new MainViewModel(&appEngine);
    appEngine.load(QUrl("qrc:/Menu/MainMenu.qml"));
    auto topLevelObject = appEngine.rootObjects().value(0);
    auto window = qobject_cast<QQuickWindow*>(topLevelObject);
    if (!window)
        qCritical("Error: Your root item has to be a Window.");
        return -1;
    window->show();
    return app.exec();
 MainMenu.qml
import QtQuick
import QtQuick.Controls
import QtQuick.Layouts
ApplicationWindow
    visible: true
    width:  1920
    height: 1080
    StackView {
        initialItem: view
        anchors.fill: parent
    Item {
            RowLayout
                width: appWindow.width
                height: appWindow.height
                spacing: 2
                Button
                    buttonText: "OPEN MAP"
                    imagePath: "qrc:///Resources/Icons/settings.png"
                    Layout.bottomMargin: 60
                    Layout.leftMargin: 20
                    function fun() {
                        stack.push(Qt.resolvedUrl("../qml/map.qml"))
Map.qml
import QtQuick
import Esri.ArcGISRuntime
Item {
   width:1920
   height: 1080
   visible: true
    MapView
        visible: true
        width:800
        height:600
        Map
            initBasemapStyle: Enums.BasemapStyleArcGISStreets
Application Console:
Thank you
JaredCaccamo
Hey @TasawarAhmad ,
There are a couple problems I am seeing.
Starting with  MainMenu.qml:
QML Button has no buttonText or imagePath properties that I am aware of, Qt Qml Button doc . Also you have defined the function fun() in button which I assume you want to be executed when the button is pressed but given how it's currently written it does nothing. You would need to either move that logic into the :onClicked signal handler or just move that function call there(e.g. onClicked: fun() ). The last problem being the qml file your are trying to add needs to have the `M` on .../qml/map.qml capitalized to .../qml/Map.qml. This is based on your post indicating the name of that file is Map.qml right below the MainMenu.qml code block above.
The primary problem with your Map.qml is that there will be naming conflicts between your QML object name Map and import Esri.ArcGISRuntime which contains a Map type. My suggestion would be just to rename your QML file something else in this case.
With those changes I was able to make your code work locally. Let me know if you have any other questions.
Happy coding!
Jared
TasawarAhmad
Hi Jared, Thank you for your reply.
I have updated my .qml code.
If I draw any rectangle in mymap.qml, then it does appear however arcgis map is not loaded.
MainMenu.qml
import QtQuick
ApplicationWindow
    visible: true
    width:  1920
    height: 1080
    StackView {
        initialItem: view
    Item {
        Image {
               source: "qrc:///Resources/Wallpapers/wallpaper2.jpg"
        ScrollView
            RowLayout
                spacing: 2
                Button
                    width:500
                    height: 100
                    onClicked:
                        stack.push(Qt.resolvedUrl("../qml/main.qml"))
main.qml
import QtQuick
import QtMultimedia
//import com.myself 1.0
Item {
   width:1920
   height: 1080
   visible: true
   Item{
    MapView
        visible: true
        width:800
        height:600
        // add a map to the mapview
        Map
            // add the ArcGISStreets basemap to the map
   Rectangle{
       color:  "black"
       width:260
       height: 260
       border.width: 2
       border.color: "yellow"
Application Console Output:
QSGThreadedRenderLoop: expose event received for window MainMenu_QMLTYPE_12(0x1706013a730 active exposed, visibility=QWindow::Windowed, flags=QFlags<Qt::WindowType>(Window), title=Ground Control Station - NG 0.0.1, geometry=482,728 1370x749) with invalid geometry: QRect(482,728 1370x749) on QScreen(0x1705ceda4e0, name=\\.\DISPLAY1)
Also interestingly, if I just load "main.qml" then map opens just fine. This issue only occurs when I navigate to "main.qml".
Thank you
TasawarAhmad
1 thing to add, the application crashes if I keep pressing any mouse button anywhere in the mapview location after navigation.
TasawarAhmad
Interestingly, If I place map in the same file as stack view then I m able to successfully navigate without any issues.
//Somewhere in the code
stack.replace(myarcgisMap)
//Placed map and stackview in the same file
StackView {
      initialItem: view
      implicitHeight: 1080
      implicitWidth: 1920
Item {
       MapView {
            // set focus to enable keyboard navigation
            focus: true
            Map {
                // add the ArcGISTopographic basemap to the map
                initBasemapStyle: Enums.BasemapStyleArcGISTopographic
                initialViewpoint: viewpoint
            ViewpointCenter {
