How to update old version?
1621
11-13-2017 12:56 AM
CeyhunYilmaz
I have Arcgis SDK For Qt 100.0.0 version. I want to update to new version(100.1.0). But i couldn't find to do it. As i see i must keep old version and install to new version too. So there will be two sdk in my workspace. Is there any solution to do this without duplicated sdk ?
Tags (1)
DanPatterson_Retired
You are following this guide...?
see Migrating from 100.0 to 100.1
And this note
100.1 supports revisions, meaning that you can install 100.1, and either import 100.1 or 100.0. You do not need to maintain separate installations of 100.0 and 100.1 on your development machine, as you can seamlessly switch between the new version and older versions with only the 100.1 installation. For this reason, it is recommended that when you want to begin migrating your apps from 100.0 to 100.1, to simply uninstall 100.0, install 100.1, and follow the above migration steps. If you must keep concurrent installations of 100.0 and 100.1 on your development machine, the post installer must be re-run each time you want to build your app for each version of the SDK to ensure that the proper version is picked up by Qt.
And this note
CeyhunYilmaz
thanks. i couldnt find the this article. i will apply them
