How to relocation Graphic in QML
1687
05-16-2021 07:22 PM
KanjaSousuke
I want to relocation Graphic.
What I want to do is click on an already placed graphic, rewrite the latitude and longitude, and reposition it.
To be more specific.
  1. click map and add point. (add PointA)
  2. click map and add point again. (add PointB)
  3. click near PointA to bring up the input screen.
  4. rewrite Lat/Long to update the display.
When I click near a point that I have already placed, can I read the information about that point?
JaredCaccamo
Hello @KanjaSousuke ,
Yes.  GeoView.identifyGraphicsOverlay will identify the topmost graphic which you can then use to obtain the graphic identified which has attributes, geometry, symbol, and a few other properties which you can see here, https://developers.arcgis.com/qt/qml/api-reference/qml-esri-arcgisruntime-graphic.html
Below I wrote a quick little example to show the functionality you seek to implement. It looks for two clicks on the map. For the first two it creates two points from those clicks. Then on all subsequent clicks it does an identifyGraphicsOverlay operation to locate the graphic you clicked near. It creates a new point using the Long and Lat from the identified graphic and add 100000 to it just to show you can update it's location. You could also take another mouse click and update it's location that way. We have many samples that illustrate similar behavior but the one that comes to mind right now is "Edit features with feature-linked annotation", https://github.com/Esri/arcgis-runtime-samples-qt/blob/main/ArcGISRuntimeSDKQt_QMLSamples/EditData/E....
import QtQuick 2.6
import QtQuick.Controls 2.2
import Esri.ArcGISRuntime 100.11
ApplicationWindow {
    width: 800
    height: 600
    title: "RelocateGraphic"
    // add a mapView component
    MapView {
        anchors.fill: parent
        // set focus to enable keyboard navigation
        focus: true
        // add a map to the mapview
        Map {
            // add the ArcGISStreets basemap to the map
            initBasemapStyle: Enums.BasemapStyleArcGISStreets
        onMouseClicked: {
            let clickPoint = screenToLocation(mouse.x, mouse.y);
            if (pointA.geometry == null) {
                pointA.geometry = clickPoint;
            } else if (pointB.geometry == null) {
                pointB.geometry = clickPoint;
                setViewpointGeometryAndPadding(overlay.extent, 100 /*padding in device independent pixels (DIPS)*/);
            } else {
                identifyGraphicsOverlay(overlay, mouse.x, mouse.y, 5 /*tolerance*/, false /*returnPopupsOnly*/);
        onIdentifyGraphicsOverlayStatusChanged: {
            if (identifyGraphicsOverlayStatus != Enums.TaskStatusCompleted)
                return;
            const result = identifyGraphicsOverlayResult;
            print("longitude: " + result.graphics[0].geometry.x);
            print("latitude: " + result.graphics[0].geometry.y);
            print("Add 100000 to long and lat respectively and update");
            let geom = result.graphics[0].geometry;
            // Point is immutable which requires us to create a new one
            // then assign it to the graphic we want to update.
            let newPoint = ArcGISRuntimeEnvironment.createObject("Point", {
        x: geom.x + 100000,
        y: geom.y + 100000,
        spatialReference: geom.spatialReference
            result.graphics[0].geometry = newPoint;
            print("new longitude: " + result.graphics[0].geometry.x);
            print("new latitude: " + result.graphics[0].geometry.y);
        GraphicsOverlay {
            Graphic {
                SimpleMarkerSymbol {
                    color: "red"
                    style: Enums.SimpleMarkerSymbolStyleCircle
            Graphic {
                    color: "blue"
                    style: Enums.SimpleMarkerSymbolStyleCross
I hope you find this helpful. Let me know if you have any other questions.
Sincerely,
Jared
JaredCaccamo
import QtQuick 2.6
ApplicationWindow {
    width: 800
    height: 600
    MapView {
        focus: true
        Map {
        onMouseClicked: {
            } else {
                return;
        x: geom.x + 100000,
        y: geom.y + 100000,
        GraphicsOverlay {
            Graphic {
                    color: "red"
            Graphic {
                    color: "blue"
Sincerely,
Jared
KanjaSousuke
Thanks, I think I can manage that.
