Export Map Image
3697
08-03-2015 09:36 AM
AndyWright
I'm looking for a quick and dirty way to export the map to an image file (jpg, png, etc).  I don't see any methods on the Map object to get that done.  Anyone have any ideas on how to accomplish this in QML?
LucasDanzinger
Esri Frequent Contributor
Yea, there isn't anything in our API yet :-/, but this is one of many cool things that we will be including in the Quartz release. If you need this now, you will need to make a Q_INVOKABLE C++ method that exposes the functionality you need to QML.
-Luke
LucasDanzinger
We will have this method on our MapView at our Quartz release, but there is no such method on the Map for 10.2.6. You will need to look into writing your own screenshot functionality using Qt, and calling your own method from QML. I haven't tried any of these, but there are some threads in stack overflow and the qt forum that have some suggestions for you to get started.
http://forum.qt.io/topic/8872/how-to-capture-an-image-in-a-qml/2
How to take ScreenShot Qt/QML - Stack Overflow
http://stackoverflow.com/questions/21697185/how-to-take-screenshot-of-qt-qml-application-without-qqu...
-Luke
AndyWright
I’ve been plowing through many links to stuff like this all morning without much success, so I was hoping there was an easy solution. Thanks for the suggestion though …
LucasDanzinger
-Luke
