Does 200 work with Qt5?
633
02-14-2023 04:27 PM
GeneHorodecki
The release notes for the 200 version indicate "now supports Qt6".  Does that mean that they do NOT support Qt5 (and that I must get 100) or does it mean that 200 supports both Qt6 and Qt5?  Thank you.
Tanner_Yould
Hi Gene, version 200.x of the ArcGIS Maps SDK for Qt does not support Qt5 and you'll need to use the LTS release 100.15.x if you need to use Qt5. This is because version 200 takes advantage of many of the changes introduced in Qt6, which makes it incompatible with Qt5.
Tanner Yould
Product Engineer
ArcGIS Maps SDK for Native Apps
Esri
