Dispaly mil2525 symbology on a map using graphicsoverlay
1535
12-18-2019 09:10 PM
AbhijeetSatam
I am using SymbolStyle and graphicsoverlay in ArcGIS qt 100.5 to read and display symbols from a style file. The code for the function is as follows. m_mapView is my MapGraphicsView object. The application is successfully built. The application crashes when this function is called. The debug statements display true status for both tw1.isValid() and for tw1.isDone() . Can somebody guide me why this problem is occurring??
void offlinemap2d::addPointsFromStyleFile()
   //create a new graphicsoverlay
   GraphicsOverlay* graphicsOverlay = new GraphicsOverlay(this);
   // create a list of points
   const QList<Point> pointsList
      Point(72.852642647560347, 19.092812566811544, SpatialReference::wgs84()),
      Point(72.8708416959572303, 19.08444173689877, SpatialReference::wgs84()),
      Point(32.6697273884990937, 56.064250073402874, SpatialReference::wgs84()),
      Point(32.6395150461199726, 56.06127916736989, SpatialReference::wgs84())
   QStringList params {"tank","friendly"};
   // create the symbology for the points
  SymbolStyle* symbolstyle1 = new SymbolStyle("/home/developer/Desktop/stylx_files/mil2525d.stylx", this);
   TaskWatcher tw1 = symbolstyle1->fetchSymbol(param);
   qDebug()<<tw1.isValid();
     while(tw1.isDone()==false)
               for(int i=1;i<500;i++)
                     qDebug()<<i;
   qDebug()<<tw1.isDone();
   symbolstyle1->fetchSymbolCompleted(tw1.taskId(),symbol1);
   foreach (const Point &buoyPoint, pointsList)
            graphic = new Graphic(buoyPoint, this);
            graphic->setSymbol(symbol1);
            graphicsOverlay->graphics()->append(graphic);
//add overlay to the map
m_mapView->graphicsOverlays()->append(graphicsOverlay);
by Anonymous User
Not applicable
At a guess. I believe the crash your seeing is to do with this line
This is a qt signal, which will be emitted at some time after your call to
and shouldn't be called directly.
(You can read more about signals and slots here : (Signals & Slots | Qt Core 5.14.0 )
Could you try replacing everything below the call to fetchSymbol with this?
connect(symbolstyle1, &SymbolStyle::fetchSymbolCompleted, this,  [graphicsOverlay, pointsList, this](QUuid taskId, Symbol* symbol)
       auto graphic = new Graphic(buoyPoint, this);
       graphic->setSymbol(symbol);
AbhijeetSatam
Hi Elliot,
I tried using your suggestion . The application is successfully built now and does not crash when run. However the points are not displayed on the map. The code I have used is as follows. The debug statement added is displayed in the console.
              qDebug()<<"inside connect";
by Anonymous User
Not applicable
My first guess would be to check if the
Symbol*
provided from the connect argument list actually contains data, or if it is null. If it's null, it probably indicates that your data has not been loaded, or that the parameters provided are not being found inside the data.
(I don't think this is neccesary, but you can also try calling
symbolstyle1.load()
immediately after the symbolStyle has been initialised. It may help.)
AbhijeetSatam
Your guess is right. Null is returned for the Symbol.
However, we are using mil2525d.stylx (http://arcgisfordefense.maps.arcgis.com/home/item.html?id=e34835bf5ec5430da7cf16bb8c0b075c) file and trying to fetch Symbol with keywords like 'tank' and 'friendly' as
Still we are not able to successfully display symbols on map.
