CIM Shape Marker / Solid Strokes rendering issue with large values for dash template, placement template
2020
8
10-06-2025 08:24 AM
imbachb
We're having rendering issues of CIM Shape Markers / Solid Strokes when using large values for dash template, placement template settings.
Here's an example:
Here's an example of smaller values for dash template, placement template properties where rendering seems fine:
Settings for J (Shape Marker):
Settings for line (Solid Stroke)
Settings for label (Shape marker)
Additionally, we noticed that setting "Perpendicular offset" on the label has no effect in 2D view, however in 3D view "Perpendicular offset" seems to work.
We would like to increase these distances between the markers to remove clutter from the screen as we might have multiple such and other lines.
We're using the latest ArcGIS Maps SDK for Qt 200.8, on Windows 10 with Direct3D.
bnoble0110
Hello @imbachb
Apologies for the delay in response, I've forwarded your issue to the appropriate team for them to take a look. Either they or I will respond back here once they've figured out the issue that you're seeing.
PreetiMaske
Hello @imbachb ,
Are you able to share a repro MMPK that is configured with this symbology? Happy to take a closer look to understand the problem. For clarification, is the issue with the size of dashes , or gaps between dashes and J marker or label placement of the label marker ?
imbachb
Sorry for getting back so late. I've attached a zip with source code and the used stylx File. The only difference between this stylx file and the official APP-6(E) from Dictionary Symbology Styles - Overview are the changes to the jammer line symbol mentioned in the first post.
The sample draws 2 lines, one using the modified jammer line and the other an unmodified bearer line:
We also noticed that certain marker placement settings for the "Maritime Lines : Bearing Line : Jammer : Friendly Labels" symbol have no effect, specifically "Angle to line", "Keep upright", "Perpendicular offset".
imbachb
@PreetiMaske Did you have the chance to follow up on this (see my latest reply)? Many thanks!
PreetiMaske
My bad, this fell off my radar. I will try and let you know by Monday what I find by testing your sample.
PreetiMaske
@imbachb , team spent some time to repro the issue. We have been able to see the differences as you reported. We can see clear differences between Static and Dynamic rendering and how some properties are getting ignored. I don't have a clear answer as to where the problem is and why but I wanted to follow up on this and let you know that we are digging into this to find where the problem is. I appreciate your patience as we troubleshoot this further. I will reach out to you if I have any further questions.
BTW, are you forcing some where in you app to render in Dynamic code. I didn't see anything explicit but still wanted to double check.
I will keep you posted as we make progress on this.
Preeti
imbachb
@PreetiMaske Thank you very much for looking into this. Thank you also for the heads up about the rendering mode. I didn't think about trying Static mode, which indeed seems to render the line as intended.
We do not set a rendering mode, so it falls back to Dynamic since it is the default rendering mode.
If you opened up a bug report could you send me the bug number so we may track it? Many thanks!
imbachb
For anyone struggling with the same issue I just found a workaround. Instead of using Marker Placement "Along line" use "Along line with variable size" with zero variable size.
This way the parameters "Angle to line" and "Keep upright" seem to be respected and there is no rendering issue.
The problem with this approach though is that it does not follow the dashed spaces perfectly anymore so in this case it can't be used for the "J" markers.
