Bug: Primitive Overrides do not work for CIMTextSymbol (Dictionary Renderer)
738
01-29-2026 04:15 AM
imbachb
We'd like to be able to dynamically adjust text sizes. We have for example following symbol containing a CIMTextSymbol. We add the primitive name "label_symbol" to the level where the height of the text symbol should be configurable.
    "type": "CIMPointSymbol",
    "symbolLayers": [
            "type": "CIMVectorMarker",
            "enable": true,
            "primitiveName": "label_r",
            "anchorPointUnits": "Relative",
            "dominantSizeAxis3D": "Z",
            "size": 10,
            "billboardMode3D": "FaceNearPlane",
            "frame": {
                "xmin": -7.5,
                "ymin": -5.0,
                "xmax": 7.5,
                "ymax": 5.0
            "markerGraphics": [
                    "type": "CIMMarkerGraphic",
                    "geometry": {
                        "x": 0,
                        "y": 0
                    "symbol": {
                        "type": "CIMTextSymbol",
                        "blockProgression": "TTB",
                        "depth3D": 1,
                        "extrapolateBaselines": true,
                        "flipAngle": 1,
                        "fontEffects": "Normal",
                        "fontEncoding": "Unicode",
                        "fontFamilyName": "Roboto",
                        "fontStyleName": "Bold",
                        "fontType": "Unspecified",
                        "haloSize": 0.75,
                        "haloSymbol": {
                            "type": "CIMPolygonSymbol",
                            "symbolLayers": [
                                    "type": "CIMSolidFill",
                                    "enable": true,
                                    "color": [
                                        0,
                                        0,
                                        0,
                                        255
                            "angleAlignment": "Map"
                        "height": 8,
                        "hinting": "Default",
                        "horizontalAlignment": "Left",
                        "kerning": true,
                        "letterWidth": 100,
                        "ligatures": true,
                        "lineGapType": "ExtraLeading",
                        "offsetX": 33,
                        "offsetY": -23,
                        "symbol": {
                            "symbolLayers": [
                                    "enable": true,
                                    "primitiveName": "label_fill",
                                    "color": [
                                        255,
                                        255,
                                        255,
                                        255
                        "textCase": "Allcaps",
                        "textDirection": "LTR",
                        "verticalAlignment": "Center",
                        "verticalGlyphOrientation": "Right",
                        "wordSpacing": 100,
                        "primitiveName": "label_symbol"
                    "textString": "staffcomment/additionalinformation"
            "scaleSymbolsProportionally": true,
            "respectFrame": true
    "haloSize": 1,
    "scaleX": 1,
    "angleAlignment": "Display"
In the dictionary script we added the primitive override referencing the primitive name
keys += ';po:label_symbol|Height|22';
which however has no effect on the rendered symbol.
Is it not possible to change the height / size of a Text Symbol dynamically through primitive overrides?
Please find attached a zip containing the stylx file with the mentioned symbol and dictionary script. It is based on APP6-(E) but I removed all other symbols and reduced the dictionary script.
We're using ArcGIS Maps SDK v200.8 on Windows 10.
megan_r
Hello @imbachb ,
I noticed a few things looking at the style you provided. In the dictionary script the primitive name is label_symbol but in ArcGIS Pro it looks like the tag used on the text symbol is label_r. Those need to be the same for the override to work, so either update the script or the Text Symbol in ArcGIS Pro so the primitive names match.
In the dictionary script I also needed to change the primitive property used in order to get the text size to actually change. Instead of using 'Height', I tried 'Size' and that seems to work:
keys += ';po:label_symbol|Size|22';
Best,
Megan
megan_r
Hello @imbachb ,
Best,
Megan
imbachb
Hi @megan_r
Thank you for the reply and the work-around. Yes, setting the size no the CIMVectorMarker seems to work, and it is more or less what we need.
It would be interesting to be able to change the height of the CIMTextSymbol via primitive overrides too, but changing the CIMVectorMarker size is good enough for now.
