Changing the text of a text graphic
3909
06-23-2015 03:26 PM
RainerFarsch
I'm putting a text graphic onto a graphic layer that shows the distance from a vehicle (Point geometry)  to a waypoint (also Point geometry). The text graphic will eventually be below the the waypoint graphic, right now it sits on top of it.  If the user changes the position of the waypoint, then the waypoint graphic changes its position, the distance between it and vehicle is recalculated, and the text is changed.
GraphicsLayer {
    // Waypoint distance graphic.
    Graphic {
        geometry: waypointCoord // Places text graphic on top of waypoint graphic - ToDo: move text graphic below waypoint graphic
        symbol: TextSymbol {
            text: courseTrack.geometry.geodesicLength()
            textColor: "white"
    onWaypointCoordChanged: {
        // Try using the cloning technique:
        var waypointDistanceTextGraphic2 = waypointDistanceTextGraphic.clone()
        waypointDistanceTextGraphic2.text = heloCoord.distance(waypointCoord)
        console.log("Waypoint distance: ", waypointDistanceTextGraphic2.text)
        waypointDistanceTextGraphic = waypointDistanceTextGraphic2
The distance printed to the console is correct, but the text graphic remains the same (in this case the geodesic length of the course track - just trying different things here). Can the text of a text graphic be changed? If so, how?
Thanks!
-Rainer
LucasDanzinger
Esri Frequent Contributor
Rainer-
The reason this is happening is because it is a value based object, so when you are getting/setting, you are seeing a copy, but the actual value is not updated. You will need to get the symbol out of the graphic, modify it, then assign it back.
GraphicsLayer {
  Graphic {
  geometry:  Point {
    x: 0
    y: 0
    spatialReference: mainMap.spatialReference
    text: "0"
Button {
  property var count: 0
  anchors {
    right: parent.right
    top: parent.top
    margins: 15
  text: "set text"
  onClicked: {
    var txtSymbol = g.symbol;
    txtSymbol.text = "some text " + count++;
    g.symbol = txtSymbol;
-Luke
OwenEarley
I haven't used the Qt SDK but in the API the TextSymbol class has a SetText method that should update the text value. The text property on the TextSymbol class only appears to return the current value.
LucasDanzinger
Rainer-
GraphicsLayer {
  Graphic {
  geometry:  Point {
    x: 0
    y: 0
    text: "0"
Button {
  anchors {
    right: parent.right
    top: parent.top
    margins: 15
  text: "set text"
  onClicked: {
-Luke
RainerFarsch
Thanks Luke,
Sounds simple enough. I was re-using the cloning technique we used for the changing the geometry on a polyline in an ealier posting; but I did not implement it correctly here. I've implemented what you have suggested and it works nicely.
Follow-up:
How would I best move the text down below the symbol marker (rather than on top of it)? I tried offsetting the geometry, but a got a major signal fault and as I understand, it would only move the text right or left of the symbol. Is there a standard way to do this? For example, is there a way to ensure that the text is always directed towards the center of the screen so there is no chance that the text gets cutoff by the left, right, top or bottom edges of the screen if the waypoint is set too close to an edge?
Thanks again!
-Rainer
LucasDanzinger
Rainer-
You can use yOffset to move it below another symbol. Take a look at what I did below. However, we don't currently have anything for conflict detection with other labels, or to know if you are moving off the screen. This is getting into more advanced labeling of features, which we plan to support in the future. I have added a note to consider the case of when labels begin to move off the screen, so that they re-arrange themselves automatically.
Luke
       GraphicsLayer {
            Graphic {
                geometry:  Point {
                    x: 0
                    y: 0
                    text: "0"
                    yOffset: -15
            Graphic {
                geometry:  Point {
                    x: 0
                    y: 0
                symbol: SimpleMarkerSymbol {
                    color: "red"
RainerFarsch
Thanks Luke,
This will do nicely for now. I should have found 'yOffset' on my own . I appreciate your time and patience.
-Rainer
