Can't draw Line in QML
3247
05-19-2021 12:26 AM
KanjaSousuke
I want to draw line. But, I can't
Where I mistake?
My code:
import QtQuick 2.6
import QtQuick.Controls 2.2
import Esri.ArcGISRuntime 100.9
ApplicationWindow {
    width: 800
    height: 600
    title: "MapTest2"
    // add a mapView component
    MapView {
        anchors.fill: parent
        // set focus to enable keyboard navigation
        focus: true
        // add a map to the mapview
        Map {
            // add the BasemapTopographic basemap to the map
            BasemapTopographic {}
        onMouseClicked: {
            pointBuilder.points.addPointXY(0, 35)
            pointBuilder.points.addPointXY(135, 35)
            lineBuilder.points.addPointXY(0, 35)
            lineBuilder.points.addPointXY(135, 35)
            pointA.geometry = pointBuilder.geometry
            lineA.geometry = lineBuilder.geometry
        GraphicsOverlay {
            Graphic {
                zIndex: 2
                SimpleMarkerSymbol {
                    color: "red"
                    style: Enums.SimpleMarkerSymbolStyleCircle
            Graphic{
                zIndex: 1
                SimpleLineSymbol {
                    style: Enums.SimpleLineSymbolStyleDash
                    width: 10
                    color: "green"
        MultipointBuilder{
            spatialReference: SpatialReference {
                wkid: 6668
        MultipointBuilder{
                wkid: 6668
This code can draw point.
Tanner_Yould
Hi @KanjaSousuke, thanks for reaching out. Fortunately this is a fairly easy fix. You'll need to use a PolylineBuilder instead of a MultipointBuilder when creating the line geometry. The PolylineBuilder does not have a points property, so you will also need to remove that when constructing your geometries. Updating the following lines should resolve your issue.
27 lineBuilder.addPointXY(0, 35)
28 lineBuilder.addPointXY(135, 35)
67 PolylineBuilder {
For more information about creating geometries in QML, I recommend taking a look at our Create geometries sample.
Thank you and please don't hesitate to follow up if there's anything else I can help with!
Tanner Yould
Product Engineer
ArcGIS Maps SDK for Native Apps
Esri
Tanner_Yould
Tanner Yould
Product Engineer
Esri
KanjaSousuke
Sorry, It was a simple misunderstanding on my part.
Thank you for bringing that to my attention.
LucasDanzinger
Esri Frequent Contributor
@KanjMadi the 100.12 release of ArcGIS Runtime now supports a SketchEditor, which greatly simplifies the workflow for sketching geometries on a map. This might be something worth considering integrating into your app. More details are in the release blog - https://community.esri.com/t5/arcgis-runtime-sdks-blog/sketcheditor-now-available-in-the-arcgis-runt...
