Animate3DSymbols and OpenMobileScenePackage Not Working
859
04-19-2019 09:50 AM
SelimOzel
Hello.
I have been trying to build and run Animate3DSymbols and OpenMobileScenePackage using QT on a Windows 10 machine. All other tutorials I worked with run fine. These two have external imports (such as 3D models) and it would be great to see the code.
Unfortunately I keep getting application errors in both of them. Do you happen to know the root cause of this? I downloaded  and copied them in the suggested folder.
Please see attached figure. Thanks!
Selim
LucasDanzinger
Esri Frequent Contributor
For the Mobile Scene Package sample, did you get a chance to download the data and place in the proper location as specified here? https://github.com/Esri/arcgis-runtime-samples-qt/tree/master/ArcGISRuntimeSDKQt_CppSamples/Scenes/O...
Regarding Animate 3D Symbols, could you try adding the following line in the init static function? Looks like we missed a registration
qmlRegisterUncreatableType<QAbstractListModel>("Esri.Samples", 1, 0, "AbstractListModel", "AbstractListModel is uncreateable");
SelimOzel
Thanks Lucas! I will go over your comments once I get back to running these. Sample projects provided in your Github have been extremely helpful!
