addPortalItemWithUrl trying to create Feature Service
1644
01-02-2018 09:01 PM
GarethWalters3
Hi everyone,
I am trying to write an app that creates a feature service, however I am seeing some strange things (or it might/hopefully just be me).  I won't go into each iteration I have tried but I will summarise some of the results and comments.
var jsonFS = appFolder.fileUrl("featureService.json")
console.log(jsonFS)
addPortalItemWithJson(newTracklog, jsonFS)
using a local file file:// (FileFolder.fileUrl from AppFramework) successfully creates the item but when I look at the service in ArcGIS.com I get an error loading the table in the data tab.  Could you please be specific to what actually has to go into this file.  I copied a previous feature layer JSON content and saved it to a file. I have attached a link at the bottom. Also the service URL is malformed.
addPortalItemWithUrl(newTracklog, https://services.arcgis.com/ZN2A4THMtsVQ15wW/ArcGIS/rest/services/TestLocationTrackingLayer/FeatureS...)
addPortalItemWithUrl(newTracklog, "https://www.dropbox.com/s/b8mvzyo82108irw/featureService.json", jsonFS)
Using a http:// file successfully added the item by using a feature service url but now the service url is pointing to the original feature service. It has effectively made a layer view. Once again what am I supposed to do with this. Also tested with a url outside of the environment and get a successful creation but invalid data.
Lucas Danzinger‌  and FYI https://community.esri.com/migrated-users/152825
https://www.dropbox.com/s/b8mvzyo82108irw/featureService.json?dl=0
Look forward to hearing what I am doing wrong
StephenQuan1
Creating a Feature Service is done in two steps:
Here is the sample parameters for Create Service:
    "name": "tracklog_101",
    "serviceDescription": "Tracklog 101 (04-Jan-2018 8:30 AM)",
    "currentVersion":10.3,
    "hasVersionedData":false,
    "supportsDisconnectedEditing":false,
    "hasStaticData":false,
    "maxRecordCount":1000,
    "supportedQueryFormats":"JSON",
    "capabilities":"Query,Editing,Create,Update,Delete",
    "description":"",
    "copyrightText":"",
    "allowGeometryUpdates":true,
    "units":"esriMeters",
    "syncEnabled":false,
    "editorTrackingInfo":{
        "enableEditorTracking":false,
        "enableOwnershipAccessControl":false,
        "allowOthersToUpdate":true,
        "allowOthersToDelete":true
    "xssPreventionInfo":{
        "xssPreventionEnabled":true,
        "xssPreventionRule":"InputOnly",
        "xssInputRule":"rejectInvalid"
    "tables":[
    "_ssl":false
Here is a sample parameters for Add To Definition:
    "layers": [
            "adminLayerInfo": {
                "geometryField": {
                    "name": "geometry",
                    "srid": 4326
            "allowGeometryUpdates": true,
            "capabilities": "Query,Editing,Create,Update,Delete",
            "copyrightText": "",
            "defaultVisibility": true,
            "description": "",
            "displayField": "",
            "drawingInfo": {
                "labelingInfo": null,
                "renderer": {
                    "description": "Tracklog",
                    "label": "Tracklog",
                    "symbol": {
                        "angle": 0,
                        "color": [
                            255,
                            0,
                            0,
                            255
                        "outline": {
                            "color": [
                                255,
                                255,
                                0,
                                255
                            "width": 1
                        "size": 8,
                        "style": "esriSMSCircle",
                        "type": "esriSMS",
                        "xoffset": 0,
                        "yoffset": 0
                    "type": "simple"
                "transparency": 0
            "extent": {
                "spatialReference": {
                    "wkid": 4326
                "type": "extent",
                "xmax": 180,
                "xmin": -180,
                "ymax": 90,
                "ymin": -90
            "fields": [
                    "alias": "ObjectID",
                    "defaultValue": null,
                    "domain": null,
                    "editable": false,
                    "name": "objectid",
                    "nullable": false,
                    "type": "esriFieldTypeOID"
                    "alias": "GlobalID",
                    "domain": null,
                    "editable": false,
                    "length": 38,
                    "name": "globalid",
                    "nullable": false,
                    "sqlType": "sqlTypeGUID",
                    "type": "esriFieldTypeGlobalID"
                    "alias": "Latitude",
                    "domain": null,
                    "editable": true,
                    "name": "latitude",
                    "nullable": true,
                    "type": "esriFieldTypeDouble"
                    "alias": "Longitude",
                    "domain": null,
                    "editable": true,
                    "name": "longitude",
                    "nullable": true,
                    "alias": "Altitude",
                    "domain": null,
                    "editable": true,
                    "name": "altitude",
                    "nullable": true,
                    "alias": "Easting",
                    "domain": null,
                    "editable": true,
                    "name": "easting",
                    "nullable": true,
                    "alias": "Northing",
                    "domain": null,
                    "editable": true,
                    "name": "northing",
                    "nullable": true,
                    "alias": "UTC Date & Time",
                    "domain": null,
                    "editable": true,
                    "name": "utcdatetime",
                    "nullable": true,
                    "type": "esriFieldTypeDate"
                    "alias": "UTC Date",
                    "domain": null,
                    "editable": true,
                    "name": "utcdate",
                    "nullable": true,
                    "alias": "UTC Time",
                    "domain": null,
                    "editable": true,
                    "length": 20,
                    "name": "utctime",
                    "nullable": true,
                    "type": "esriFieldTypeString"
                    "alias": "Sentence",
                    "domain": null,
                    "editable": true,
                    "length": 255,
                    "name": "sentence",
                    "nullable": true,
            "geometryType": "esriGeometryPoint",
            "globalIdField": "globalid",
            "hasAttachments": true,
            "hasM": false,
            "hasStaticData": false,
            "hasZ": false,
            "htmlPopupType": "esriServerHTMLPopupTypeAsHTMLText",
            "id": 0,
            "isDataVersioned": false,
            "maxRecordCount": 1000,
            "maxScale": 0,
            "minScale": 0,
            "name": "Tracklog",
            "objectIdField": "objectid",
            "relationships": [],
            "supportedQueryFormats": "JSON",
            "supportsAdvancedQueries": true,
            "supportsRollbackOnFailureParameter": true,
            "supportsStatistics": true,
            "templates": [],
            "type": "Feature Layer",
            "typeIdField": "",
            "types": [],
            "indexes": [
                    "description": "GlobalID index",
                    "fields": "globalid",
                    "isAscending": false,
                    "isUnique": true,
                    "name": "GlobalIDIndex"
StephenQuan1
    "description":"",
    "copyrightText":"",
    "tables":[
    "_ssl":false
    "layers": [
            "adminLayerInfo": {
                "geometryField": {
                    "name": "geometry",
                    "srid": 4326
            "description": "",
            "displayField": "",
            "drawingInfo": {
                "renderer": {
                    "symbol": {
                        "angle": 0,
                        "color": [
                            255,
                            0,
                            0,
                            255
                        "outline": {
                            "color": [
                                255,
                                255,
                                0,
                                255
                            "width": 1
                        "size": 8,
                        "type": "esriSMS",
                        "xoffset": 0,
                        "yoffset": 0
                    "type": "simple"
                "transparency": 0
            "extent": {
                    "wkid": 4326
                "type": "extent",
                "xmax": 180,
                "xmin": -180,
                "ymax": 90,
                "ymin": -90
            "fields": [
                    "domain": null,
                    "editable": false,
                    "name": "objectid",
                    "nullable": false,
                    "domain": null,
                    "editable": false,
                    "length": 38,
                    "name": "globalid",
                    "nullable": false,
                    "domain": null,
                    "editable": true,
                    "name": "latitude",
                    "nullable": true,
                    "domain": null,
                    "editable": true,
                    "nullable": true,
                    "domain": null,
                    "editable": true,
                    "name": "altitude",
                    "nullable": true,
                    "alias": "Easting",
                    "domain": null,
                    "editable": true,
                    "name": "easting",
                    "nullable": true,
                    "domain": null,
                    "editable": true,
                    "name": "northing",
                    "nullable": true,
                    "domain": null,
                    "editable": true,
                    "nullable": true,
                    "domain": null,
                    "editable": true,
                    "name": "utcdate",
                    "nullable": true,
                    "domain": null,
                    "editable": true,
                    "length": 20,
                    "name": "utctime",
                    "nullable": true,
                    "domain": null,
                    "editable": true,
                    "length": 255,
                    "name": "sentence",
                    "nullable": true,
            "hasM": false,
            "hasZ": false,
            "id": 0,
            "maxScale": 0,
            "minScale": 0,
            "name": "Tracklog",
            "templates": [],
            "typeIdField": "",
            "types": [],
            "indexes": [
                    "isUnique": true,
