Add WFS layer from GeoServer
3148
04-27-2020 10:02 AM
ViníciusCosta
Hello, I've been trying to create a sample application that uses a WFS layer from a locally hosted GeoServer but I can't figure it out how to do it.
I managed to use a WMS service with the following code:
   WmsLayer {
          url: "http://localhost:8080/geoserver/wms"
           layerNames: ["Test:tbl_furos_coordenadas_2"]
And I've tried this to WFS but to no avail:
 FeatureLayer{
                WfsFeatureTable {
                    url:"http://localhost:8080/geoserver/Test/wfs"
                    tableName: "tbl_furos_coordenadas_2"
                    featureRequestMode: Enums.FeatureRequestModeManualCache
                    onLoadStatusChanged: {
                        if (loadStatus !== Enums.LoadStatusLoaded)
                            return;
                        populateWfsFeatureTable();
But nothing happens. Is there something I'm missing?
LucasDanzinger
Esri Frequent Contributor
did you try out this sample? arcgis-runtime-samples-qt/DisplayWfsLayer.qml at master · Esri/arcgis-runtime-samples-qt · GitHub
if you swap out the url and tableName, it should work. If it doesn't perhaps the URL is formatted wrong? I also notice you are setting the FeatureLayer.name property, but that is read-only (LayerContent QML Type | ArcGIS for Developers )
Can you connect to the errorChanged signal and see if you get any errors:
WfsFeatureTable {
    onErrorChanged: {
        console.log(error.message, error.additionalMessage);
FeatureLayer {
    onErrorChanged: {
LucasDanzinger
WfsFeatureTable {
    onErrorChanged: {
FeatureLayer {
    onErrorChanged: {
ViníciusCosta
Sorry for the late answer, I'm gonna try this, thank you.
ViníciusCosta
We're not using it anymore so I'm not in need of this right now. Thank you for your help!
