Flatten nested data
1724
6
02-18-2025 09:27 PM
DanPatterson
MVP Esteemed Contributor
2 6 1,724
Replace the numbers below with anything you want.
lst = [
       [[1, 2, 3], [4, 5]],
       [[1, 2]],
       [1, 2],
       [[1, 2, 3], [4, 5], [6, 7, 8]],
       [[[1, 2, 3], [4, 5]], [[6, 7, 8]]],
Flatten with recursion (a function calling itself 'recursively')
def flatten(a_list, flat_list=None):
    """Change the isinstance as appropriate.
    :  Flatten an object using recursion
    :  see: itertools.chain() for an alternate method of flattening.
    if flat_list is None:
        flat_list = []
    for item in a_list:
        if isinstance(item, list):
            flatten(item, flat_list)
        else:
            flat_list.append(item)
    return flat_list
Simple flattening
flatten(lst)
[1, 2, 3, 4, 5, 1, 2, 1, 2, 1, 2, 3, 4, 5, 6, 7, 8, 1, 2, 3, 4, 5, 6, 7, 8]
Who says you can't start out with initial values.
flatten(lst, ['a', 'b']))
['a', 'b', 1, 2, 3, 4, 5, 1, 2, 1, 2, 1, 2, 3, 4, 5, 6, 7, 8, 1, 2, 3, 4, 5, 6, 7, 8]
6 Comments
Contributors
About the Author
Retired Geomatics Instructor (also DanPatterson_Retired). Currently working on geometry projects (various) as they relate to GIS and spatial analysis. I use NumPy, python and kin and interface with ArcGIS Pro.
