Zooming in Using ArcPy
4865
7
07-07-2022 07:46 AM
MM598
I am working in ArcPro and trying to create a print tool in which the user makes a point, then the camera zooms into the polygon within that point, and a report is generated with the layout zoomed into that polygon. Any suggestions for code I could use to zoom into a selected polygon?
Edit: removed extraneous information, clarity
DannyMcVey
Esri Alum
This method is working fine for me in the Pro python window.
aprx = arcpy.mp.ArcGISProject("CURRENT")
mv = aprx.activeView # mapview
m = mv.map # map
mv.camera.setExtent(mv.getLayerExtent(m.listLayers('USA_Counties_Generalized')[0]))
This works because "getLayerExtent" honors any active selection.
RhettZufelt
MVP Notable Contributor
You must be in Pro?  Since arcpy.mapping (ArcMap) was replaced with arcpy.mp.  Should be able to find what you need there.
R_
MM598
Unfortunately, arcpy.mapping does not translate easily to arcpy.mp.
DanPatterson
MVP Esteemed Contributor
Solved: Zoom/Pan to layer using Arcpy - Esri Community
a suggestion from one of the links to the right of your thread
... sort of retired...
MM598
No, arcpy.mapping is deprecated and does not translate easily to arcpy.mp.
RhettZufelt
Not sure what you mean by "deprecated".  If you are using ArcMap, then you use arcpy.mapping.  If you are on Pro, it's arcpy.mp.
The link I provided makes it easier to "translate" to arcpy.mp.
Maybe someone else knows a different way, but I think these are your options to control the "Map" with arcpy.
R_
DannyMcVey
Esri Alum
m = mv.map # map
MM598
This works. However, it is not working in ArcOnline once I upload the tool. That may call for a different post. . . Thanks for your help!
