Zoom Out Slightly When Using getLayerExtent() To Set Extent of Map Frame
4641
7
08-23-2023 12:09 PM
BrettLessner_Nsight
I have a set of layouts where their extents change based on the county being published. Basically, the script  sets the definition query of the County layer and then uses
mf.camera.setExtent(mf.getLayerExtent(lyr, False, True))
to move the layout extent. However, this zooms too far in on the county boundaries. The goal is to zoom to the extent of the county layer - n%.
I've attached current results vs goal
TylerT
I have to perform this operation also.  Here's what I do that seems to work fine.
After you camera.setExtent like you did:
Notice you can both get and set the camera scale with mf.camera.scale.
HTH.
Tyler
Shauna-RaeBrown
I've had the same problem.  I am forced to set the map's layout scale after my feature is drawn from the x/y coordinates.  Here's a snippet of what I do after running a script that collects data from a "utility marking request" that draws the feature from Lat/Long coordinates.
lyt = aprx.listLayouts()[0]
mf = lyt.listElements("MAPFRAME_ELEMENT", "MainMapFrame")[0]
mf.camera.scale = 24000.0
After the script runs, I have to zoom to the feature using Pro (version 2.9).
I think Esri needs to make the getLayerExtent() to allow for a percentage, like when you "zoom to selected feature" or for a map book layout where you can set a percentage for the feature extent in Pro.  Maybe you could submit it as a Python Idea.  Just a thought.
BrettLessner_Nsight
Thanks for sharing your experience. I'll wait to see if I'm missing an option or setting somewhere, but I think we'll have to.
One alternative we're looking into is finding the extent of the layer, do math on the x/y max/min, and use the updated values to set our extent.
-Brett
TylerT
HTH.
Tyler
edward33
This worked so well, thanks for the tip!
DougBrowning
MVP Esteemed Contributor
@TylerT marking as solution as that is super slick!  -1 point for having a screen shot vs text so I can't copy/paste lol
thanks!
CMorneau
Hello to All,
I was looking for a solution to the same issue & found this thread.  We can do this in an ArcMap project with way different syntax, but I'm in the process of migrating that project to Pro.  So, I got a little stuck.
Agreed - Tyler's solution worked for me as well.  Interesting that when typing mf.camera into Pro's built-in Python window, scale isn't exposed when typing a period after camera.  It would be nice if Esri added that to the menu.  At first, I didn't think it would work, but what-the-heck, why not give it a try.  Voila!  It worked.
Let's take this a little further.  I like to round up the layout scale once I've zoomed out using the 1.1 factor.  Adapting from my old ArcMap script, try adding this:
mf.camera.scale -= mf.camera.scale % -100.
I'm not much of a Python programmer, so maybe someone who's more knowledgeable can combine that line of code with Tyler's code to make it cleaner & more concise.
-Chris
TylerT
Hi @CMorneau,
You can add this line after factoring to round up to nearest 100.
mf.camera.scale = math.ceil(mf.camera.scale / 100) * 100
Note: Add `import math` to your imports.
HTH,
Tyler
