where clause of my selectlayerbyattribute_management keeps returning error
2539
03-26-2013 07:43 AM
KP
Refering to ArcGIS 10 Help, I have tried writting my where clause exactly as stated in the help (using quotes, brakets, etc) and I keep getting Error 000358: Invalid expression Failed to execute (SelectLayerByAttribute).  I am running this inside arcmap.
arcpy.SelectLayerByAttribute_management("zipcode_27012", "NEW_SELECTION", "NAME" = '27012')
There must be something obvious I am missing.
JakeSkinner
Esri Esteemed Contributor
Hi Kevin,
What type of data are your working with (i.e. shapefile, File Geodatabase feature class, Personal Geodatabase feature class)?
Try the following:
arcpy.SelectLayerByAttribute_management("zipcode_27012", "NEW_SELECTION", "NAME = '27012'")
KP
Simply a shapefile.
JakeSkinner
The syntax I posted initially should work.
KP
I ended having to use three(""") to get it to work.
