Trying to change elementWidth
1437
03-25-2013 10:31 AM
courtneygarlock
Hi
I'm using the following code:
import arcpy
mxd = arcpy.mapping.MapDocument(r"C:\Courtney\TEST.mxd")
for elm in arcpy.mapping.ListLayoutElements(mxd, "TEXT_ELEMENT"):
    if elm.name == "author":
        elm.text = '<dyn type="document" property="author"/>'
        elmWidth = 2.5
        elm.elementPositionX = 3.23
        elm.elementPositionY = 8.54
        print elmWidth
prints 2.5
The script runs fine but when I open the mxd the xy position is changed but not the elmWidth, is there another way to change
element width bc I've tried it a bunch of times and nothing works.
Also is there a better script to add title, author, dataframe time to the layout without having to set each xy position and element width?
Thank you
LucasDanzinger
Esri Frequent Contributor
If you are working with the 'current' map document, did you make sure to use arcpy.RefreshActiveView()? Also, are you making sure to do mxd.save() at the end?
courtneygarlock
I am not working in "current" I am working in pywin 2.7  and I do save.mxd() and the width still isn't changing, only the xy position will change.
JeffBarrette
elmWidth = 2.5 should be elm.elementWidth = 2.4
Jeff
