What is the equivalent of arcpy.ExtractData_production in Pro?
2767
5
10-20-2018 11:09 AM
ThomasColson
arcpy.ExtractData_production("G[name_of_feature_dataset]",GDB,"DO_NOT_REUSE","","","") has served me well for many years to extract an entire (complete, everything in it) Feature Dataset from a SDE to a FGDB for field use. What is the equivalent, in Pro Python, of extracting an ENTIRE Feature Dataset (that could contain many hundreds of feature classes, thus not suitable for individually listing each one using Feature Class To Geodatabase—Conversion toolbox | ArcGIS Desktop )
DanPatterson_Retired
is this an a production mapping extension in arcmap?
Load Data—Topographic Production toolbox | ArcGIS Desktop which is strange but that is the only thing searching Production in the help  is
Production in ArcGIS Pro—ArcGIS Pro | ArcGIS Desktop
I assume you have gone through
Tools that are not available in ArcGIS Pro—Appendices | ArcGIS Desktop
where lots of metadata stuff still isn't over
ThomasColson
yes, in arcmap you need Production Mapping License for the python tool to work. Also licensed in Pro, tool does not work, as I suspect it doesn't exist.
That 'Load' one was as close as I could find since it requires
ArcGIS Desktop Standard: Requires Production Mapping
maybe it is around somewhere within
always check ArcGIS Ideas‌
Add the Extract Data Tool from the ArcMap Production Mapping Toolbox in Pro
you already gave it a bump up at some time
ThomasColson
I even have a list of "Ideas" (Arc Map Functionality Missing Bugs) that I've voted on. List is so long I missed this.....
