What is the difference between using the arcpy management module (eg. arcpy.management.CalculateField) and the arcpy.CalculateField_management method?
2568
11-16-2021 03:27 AM
brianlin
The documentation for the arcpy modules under ArcGIS Pro are all using the arcpy.management module https://pro.arcgis.com/en/pro-app/latest/tool-reference/data-management/calculate-field.htm
compared to the ArcMap documentation where the methods are sitting in arcpy.  https://desktop.arcgis.com/en/arcmap/latest/tools/data-management-toolbox/calculate-field.htm
There appears to be no difference in performance between the two in ArcGIS Pro/arcpy 2.8.
So I was curious if anyone has any insight between the two?
DanPatterson
MVP Esteemed Contributor
They are the same
In the new toolbox structure (since 2.8) the calculate field tool is located in
C:\....YourInstallFolder...\Resources\ArcToolBox\toolboxes\Data Management Tools.tbx\CalculateField.tool
"management" is the alias for Data Management in arctoolbox
and the script is located in
C:\....YourInstallFolder...\Resources\ArcPy\arcpy\management.py
You can examine at your leisure the association between the two incarnations of methods of referencing tools in the script
C:\....YourInstallFolder...\Resources\ArcPy\arcpy\toolbox.py
Examining the scripts in various locations you can find out how arcpy and tools work together
PS  I moved this to Python Questions since it isn't associated with the python api
... sort of retired...
DanPatterson
They are the same
