Want FeatureVerticesToPoints_management functionality in ArcGIS 10.1 Standard or any other alternative to get points of vertices
2437
9
11-09-2017 02:41 AM
vikaswardiya
New Contributor II
Hello Everyone,
   I need to run arcpy.FeatureVerticesToPoints_management() method in ArcGIS 10.1 Desktop Standard, but it has License just for ArcGIS Desktop Advanced. Can anyone suggest me any other alternative to get the point layer of the vertices like I get in  FeatureVerticesToPoints_management() method..
Thanks and Regards..
XanderBakker
Esri Esteemed Contributor
Find below the code that I used to recreate the Feature Vertices To Points tool for Basic licenses (sorry for the Spanish interface):
Code for the tool:
# Name:        FeatureVerticesToPoints.py
# Purpose:     Convertir los vertices de features a puntos
# Author:      xbakker
# Created:     27/02/2015
import arcpy
import os
def main():
    # parameters
    fc_in = arcpy.GetParameterAsText(0)
    fc_out = arcpy.GetParameterAsText(1)
    method = arcpy.GetParameterAsText(2)
    # fld para poder hacer el join con la entrada
    fld_oid_in = "OIDentrada"
    # geometria de salida
    geomtype = "POINT"
    sr = arcpy.Describe(fc_in).spatialReference
    # recreate fc_out based on fc_lines (in)
    ws_name, fc_name = os.path.split(fc_out)
    createFeatureClass(fc_out, fc_in, geomtype, sr)
    # add OID field
    arcpy.AddField_management(fc_out, fld_oid_in, "LONG")
    # cursors:
    cnt = 0
    flds_out = ("SHAPE@", fld_oid_in)
    with arcpy.da.InsertCursor(fc_out, flds_out) as curs_out:
        flds_in =("SHAPE@", "OID@")
        with arcpy.da.SearchCursor(fc_in, flds_in) as curs:
            for row in curs:
                feat = row[0]
                oid = row[1]
                # get vertices
                lst_vertices = getVertices(feat, method)
                # store vertices
                for vertice in lst_vertices:
                    cnt += 1
                    if cnt % 100 == 0:
                        arcpy.AddMessage("Procesando punto: {0}".format(cnt))
                    curs_out.insertRow((vertice, oid, ))
def getVertices(feat, method):
    """Convertir poligono o linea a puntos dependiendo del metodo"""
    if feat.type == "polygon":
        polyline = feat.boundary()
    else:
        polyline = feat
    lst_vertices = []
    if method == "ALL":
        for part in polyline:
            for pnt in part:
                lst_vertices.append(pnt)
    elif method == "MID":
        pnt = polyline.positionAlongLine(0.5, True)
    elif method == "START":
        lst_vertices.append(polyline.firstPoint)
    elif method == "END":
        lst_vertices.append(polyline.lastPoint)
    elif method == "BOTH_ENDS":
    return lst_vertices
def createFeatureClass(fc_out, fc_in, geomtype, sr):
    arcpy.CreateFeatureclass_management(ws_name, fc_name, geomtype, spatial_reference=sr)
if __name__ == '__main__':
    main()
DanPatterson_Retired
FeatureClassToNumPyArray with the explode_to_points option set to True
http://desktop.arcgis.com/en/arcmap/latest/analyze/arcpy-data-access/featureclasstonumpyarray.htm
Then Numpyarraytofeatureclass to get the exploded geometry back to points.
Or some searchcursor approach doing effectively what the above does
vikaswardiya
New Contributor II
Sir,As per your approach,The coordinates I am getting are of the center of the lines, Is there any way to get the vertices of the line i.e. the start and the end points of the line.
rgomes
New Contributor III
You can create two fields for start point and two fields for end points of line (XStart / YStart / XEnd / YEnd), and use 'Calculate Geometry' to get this coordinates.
You didn't specify the explode_to_points=True (check http://desktop.arcgis.com/en/arcmap/latest/analyze/arcpy-data-access/featureclasstonumpyarray.htm
that is why you are getting the centroid only
rgomes
New Contributor III
If you need only the Coordinates of points and working with Enterprise Geodatabase, you can read the coordinates with a Query layer or using the RDBMS tools with a function like ST_ASTEXT and getting all of the coordinates.
XanderBakker
Code for the tool:
# Author:      xbakker
import arcpy
import os
def main():
    # parameters
    geomtype = "POINT"
    # add OID field
    # cursors:
    cnt = 0
            for row in curs:
                feat = row[0]
                oid = row[1]
                # get vertices
                # store vertices
                    cnt += 1
                    if cnt % 100 == 0:
    else:
        polyline = feat
    lst_vertices = []
    if method == "ALL":
            for pnt in part:
    return lst_vertices
    main()
vikaswardiya
New Contributor II
Thank you very much sir, My problem is solved now.
matu89
New Contributor II
hey, i cannot run that script it wont run .
here is the error:
any help would be appriciate!
thanks!
JordanKeller
New Contributor II
I'm getting the same error with this code. It worked for me in ArcMap but not when I run it in Pro.
Could it be differences between Python 2 and 3? I'm not familiar enough with syntax differences between the two that might be tripping me up in Pro. Any ideas?
