VB conditional statement not working in calculate field tool
2615
05-24-2011 09:11 AM
CrystalCarreon
I am writing a python script which utilizes the expression & code block parameter in the calculate field tool to populate values for a specific field. The code block uses a conditional If,Then, Else statement to understand the value of an existing field (Num_Value) in order to calculate the value of another field (Num_Text). However, I keep receiving the error "(Microsoft VBScript compilation error) Expected end of statement". See script below:
CodeBlock = "dim X as string \\nIf [Num_Value] = 1 Then \\nX = \"Poor\" \\nElse X = \"Good\" \\nEnd If"
gp.CalculateField_management(InputFeature,"Num_Text","X","VB",CodeBlock)
Any ideas as to what I am doing wrong within the VB code block??
Any help is greatly appreciated!
Thanks!
P.S. Using arcmap 9.2
DarrenWiens2
I using ArcGIS 10, so I can't test this. But, in 10 you can use VBScript for the code block (although I'm not completely sure what 9.2 uses - the help says standard VB). I know that VBScript doesn't like it when you dim variables AS a datatype. I suggest either not dimming your variable, or at least remove "as string".
CrystalCarreon
That did the trick! Thanks so much!
When I used that bit of code just within ArcMap it worked fine so I figured I would include it but I guess not!
Thanks again!
DarrenWiens2
No problem - I've spent a lot of time tilting at that windmill in the past!
PaulGrimes
Great post, perfect solution that saved me hours of head scratching. Thanks for taking the time to post the solution.
Paulg
