Trying to create a point shapefile from a text file
2115
07-06-2011 02:16 AM
MikeSquires
I am attempting to create a point shapefile from a text file.  The text file is space delimited with three columns; latitude, longitude, and snowfall.  I have done this before in ArcGIS 9.x.  However in Arc 10 I am having problems.  The script below produces a shapefile with the proper attributes and number of rows, but the geometry is messed up.  All points are located at 0, 0 lat/lon.  I have tried multiple variations but keep coming up with the same problem.  I have SP2 installed.  Any suggestions are appreciated.
DanPatterson_Retired
as of version 10, properties are case sensitive, hence your line
point.x
should be
point.X
and
point.Y    and   point.ID
MikeSquires
Thanks Dan!  Can you suggest any references for ArcPy, especially for converting existing code.
Mike
Start here   http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#//000v00000001000000.htm  and keep reading.
other tips from within Pythonwin or other command line IDE
>>> import arcpy
>>> dir(arcpy)
['ASCII3DToFeatureClass_3d', 'ASCIIToRaster_conversion', 'AddCADFields_conversion', 'AddCodedValueToDomain_management', 'AddColormap_management', 'AddError', 'AddFeatureClassToTerrain_3d', 'AddFeatureClassToTopology_management', 'AddFieldDelimiters', 'AddFieldToAnalysisLayer_na', 'AddField_management', 'AddGlobalIDs_management', 'AddIDMessage', 'AddIndex_management', 'AddItem_arc', 'AddJoin_management', 'AddLocations_na', 'AddMessage', 'AddRastersToMosaicDataset_management', 'AddRepresentation_cartography', 'AddReturnMessage', 'AddRuleToTopology_management', 'AddSpatialIndex_management',.....etc etc
Or for a particular class...
>>> dir(arcpy.Point)
['ID', 'M', 'X', 'Y', 'Z', '__class__', '__delattr__', '__dict__', '__doc__', '__eq__', '__format__', '__getattribute__', '__hash__', '__init__', '__module__', '__new__', '__reduce__', '__reduce_ex__', '__repr__', '__setattr__', '__sizeof__', '__str__', '__subclasshook__', '__weakref__', '_arc_object', '_go', 'clone', 'contains', 'crosses', 'disjoint', 'equals', 'overlaps', 'touches', 'within']
Or for help...
>>> help(arcpy.Point)
Help on class Point in module arcpy.arcobjects.arcobjects:
class Point(arcpy.arcobjects.mixins.PointMixin, arcpy.arcobjects._base._BaseArcObject)
|  The point object is used frequently with cursors. Point features return a
|  single point object instead of an array of point objects. All other feature
|  typesâ�?��?�polygon, polyline, and multipointâ�?��?�return an array of point
|  objects or an array containing multiple arrays of point objects if the
|  feature has multiple parts.
|  Method resolution order:
etc
etc etc
Have fun
MikeSquires
Thanks!  This is helpful.
Mike
