ValueError: Unable to create the manifest (sddraft file). An unspecified error occurred.
3472
7
03-04-2022 11:45 AM
ColeNelson
Hey all, I am trying to create a tool that will allow me to enter my portal username and password, then overwrite an existing map service once it has been updated in ArcGIS Pro.
import arcpy
import os
UserName = arcpy.GetParameterAsText(0)
Password = arcpy.GetParameterAsText(1)
arcpy.SignInToPortal("https://giswebmap.isrb.com/portal",UserName,Password)
outdir = r"I:\GIS\GIS_Monthly_Updates\ForDeveloping\PCC_ServeDef"
service_name = "PCC"
sddraft_filename = service_name + ".sddraft"
sddraft_output_filename = os.path.join(outdir,sddraft_filename)
sd_filename = service_name + ".sd"
sddraft_output_filename = os.path.join(outdir,sd_filename)
aprx = arcpy.mp.ArcGISProject(r"I:\GIS\GIS_Monthly_Updates\ForDeveloping\GIS_Monthly_Update.aprx")
m = aprx.listMaps('PCC')[0]
server_type = "FEDERATED_SERVER"
federated_server_url = "https://giswebmap.isrb.com/server"
sddraft = m.getWebLayerSharingDraft(server_type,"MAP_IMAGE",service_name)
sddraft.federatedServerUrl = federated_server_url
sddraft.overwriteExistingService = True
sddraft.exportToSDDraft(sddraft_output_filename)
print("Start Staging")
arcpy.StageService_server(sddraft_output_filename, sddraft_output_filename)
print("Start Uploading")
arcpy.UploadServiceDefinition_server(sddraft_output_filename, federated_server_url)
print("Finish Publishing")
This is a sample code that I copied and pasted, then manipulated, from ESRI's website, hoping that it would work.  However when I run it I keep getting this error message:
File "I:\GIS\GIS_Monthly_Updates\DevelopmentScripts\PublishServiceDefinition.py", line 25, in <module>
File "C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\sharing.py", line 68, in exportToSDDraft
return _convertArcObjectToPythonObject(self._arc_object.exportToSDDraft(out_sddraft,self))
Any suggestions to what may be causing this and how I can go about fixing it?  Thanks in advance for the help.
SomaChatterjee
I am trying to over-write a feature service in ArcGIS online. I am using the ESRI's code and twigged it depending on my need. However, I am getting  the following error:
File C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\sharing.py, in exportToSDDraft:
Line 24:    return _convertArcObjectToPythonObject(self._arc_object.exportToSDDraft(out_sddraft, self))
ValueError: Service and/or folder name contains unsupported characters: : ,. ,/
Any suggestions on this issue will be thankfully appreciated.
RyanJones6
I know this is a year late but I was getting the same error when trying to create a gp service from a very similar script. The script would work locally but would crash with this error when trying to run from the gp service. The fix for me would be to add the 'offline' property for sddraft. This would allow my 'arcgis' user to export the sddraft file even if it wasnt signed in. So possibly adding this line would fix your issue:
sddraft.offline = True
MaartendeJong
Thanks. That sorted out my issue
René_Ténière
@RyanJones6 that fixed my issues. Thanks!
chris_del101
I still have this issue. My project path had lots of special chars and it cannot be changed
'serviceName': 'C:\\Users\\me\\OneDrive - My Company Consulting Ltd. (Inc)\\Documents\\ArcGIS\\Projects\\MyProject1\\myService.sddraft',
 What can I do to solve this? I need this path to work
Although even after replacing it with this I still get the error
myService.sddraft
Source: https://pro.arcgis.com/en/pro-app/latest/tool-reference/server/stage-service.htm#L_
I think there must be some other issue and the error message is just leading me down the wrong path.
René_Ténière
Paths with spaces should be double quoted...
'serviceName': '"C:\\Users\\me\\OneDrive - My Company Consulting Ltd. (Inc)\\Documents\\ArcGIS\\Projects\\MyProject1\\myService.sddraft"',
chris_del101
I was able to solve this using
r'C:\\Users\\me\\OneDrive - My Company Consulting Ltd. (Inc)\\Documents\\ArcGIS\\Projects\\MyProject1\\myService.sddraft',
 But this one I cannot get to work.
s = r"C:\Users\me\Downloads\Publish as Web Layer (1).aprx"
'C:\\Users\\me\\Downloads\\Publish as Web Layer (1).aprx'
 These are not set by me and are the paths of files so cannot be changed. The problems seems to be with the last part of the string (and it's nothing to do with the aprx extension).
