Using SearchCursor to read two columns and process
6056
14
08-16-2018 12:07 AM
Thiru_P
Hi Python experts, I am writing my first python script and would need some advice on how to read and manipulate a list.
On my network drive, I have several folders named after Project and they belong to one or more Years.
I have a FGDB feature class in which I have 2 desired columns FLYING, FILMNAME representing Year, Project respectively.
For e.g.,
YearProject
1960A
1972B
1980C
1972D
1980E
1980F
1960G
1972H
1972I
1960J
I would like to read all the rows and create one mosaic data set for each Year and add the Project into each Year's mosaic .
e.g, 1960 will have A;G;J 1972 will have B;D;H
To do this, I would like to get two lists
1. a list of unique Years - to create empty mosaics
2. a list of Projects per Year - to append airphoto folders to each mosaic
Below is the code that does the first list. Any pointers on how to progress further would be much helpful. Thanks in advance.
#import modules
import os
import arcpy
from arcpy import env
from datetime import datetime
#assign variables
in_fc = r'C:\Working\airphoto.gdb\airphoto_index'
fields = ['FLYING','FILMNAME']
gdb = 'C:\Working\images.gdb'
sourceDir = "O:\\airphoto\\75dpi\\"
in_mosaic = 'C:\Working\images.gdb\test'
prjfile = arcpy.SpatialReference(3857)
#create lists
Years = []
Films = []
YearFilmString = []
FilmList = []
#read feature class columns and iterate through rows
with arcpy.da.SearchCursor(in_fc,fields) as cursor:
    for row in cursor:
        #extract year from datetime field
        yearString = (str(row[0])[:4])
        Years.append(yearString)
        filmString = row[1]
        Films.append(filmString)
uniqYears = sorted(set(Years))
uniqYearsList = list(uniqYears)
#for each year, create one mosaic
for i in uniqYearsList:
    x = "C:\Working\images.gdb\T"+i
    if arcpy.Exists(x):
        print "mosaic already exists, skipping..."
        continue
    else:
        arcpy.CreateMosaicDataset_management(gdb,i,prjfile,'','','','')
        print  i, "mosaic created"
RandyBurton
Here's another of many ways:
cursor = [ # rows in your geodatabase
    [ '1960-01-01', 'A' ],
    [ '1972-01-01', 'B' ],
    [ '1980-01-01', 'C' ],
    [ '1972-02-01', 'D' ],
    [ '1980-02-01', 'E' ],
    [ '1980-03-01', 'F' ],
    [ '1960-02-01', 'G' ],
    [ '1972-03-01', 'H' ],
    [ '1972-04-01', 'I' ],
    [ '1960-03-01', 'J' ]
d = {} # empty dictionary
# with arcpy.da.SearchCursor(in_fc,fields) as cursor:
#    for row in cursor:
for row in cursor:
    if row[0][:4] not in d:
        d[row[0][:4]] = [row[1]]
    else:
        d[row[0][:4]].append(row[1])
print d
# {'1960': ['A', 'G', 'J'], '1972': ['B', 'D', 'H', 'I'], '1980': ['C', 'E', 'F']}
for k in d.keys():  # access years and films
    print k
    print d[k]
1960
['A', 'G', 'J']
1972
1980
['C', 'E', 'F']
DanPatterson_Retired
what message did you get... or what happened when you ran the script?
Lines 30-on need to be dedented since you would want to create th mosaic dataset after you have assembled all the parts not while you are within the searchcursor
Thiru_P
Thanks, Dan. I copied and pasted partial code. My bad. Checked it. I have updated the snippet now.
What happens? anything?  no errors or output?
do you want the year to be the name (ie 'i') or do you want 'T' in front of the year, since you test 'x' to see if it exists.
Thiru_P
Hi Dan, it works fine. All the mosaics (T1960, T1972..) are created with prefix "T" just because, the mosaic names cant start with a number.
I have not figured out how to construct the list of films (projects) for each year and this is where I need help from.
I was reading your List Comprehension posts (Great contributions, btw) and could not figure how I can apply it.
Do I use array or dictionary?
year = [1960, 1972, 1980, 1972, 1980, 1980, 1960, 1972, 1972, 1960]
Project = ['A', 'B', 'C', 'D', 'E', 'F', 'G', 'H', 'I', 'J']
keys = sorted(list(set(year)))
a = np.array(list(zip(year, Project)), dtype=[('year', '<i4'), ('project', 'U2')])
out = []
for i in keys:
    kv = [i]
    idx = np.where(a['year'] == i)
    vals = a[idx]['project']
    kv.append(vals.tolist())
    out.append(kv)
out
[[1960, ['A', 'G', 'J']], [1972, ['B', 'D', 'H', 'I']], [1980, ['C', 'E', 'F']]]‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
EDIT
line 0   ADD the following line
import numpy as np
Sorry... been doing a lot of array programming lately so I found this the quickest.
 Get the unique years (line 4)
Take your year and projects and form an array (or a list of lists). (line 5)
Then extract the projects for each year in the keys (line 8).
kv is just a small list to append the project list.
do what you want with the list of lists... you could make a dictionary if needed
Thiru_P
Hi Dan, tried this. I am getting empty list for the Projects.
[['1944', []], ['1948', []], ['1956', []], ['1957', []], ['1958', []], ['1959', []], ['1962', []], ['1963', []], ['1964', []], ['1968', []], ['1969', []], ['1970', []], ['1972', []], ['1973', []], ['1974', []], ['1976', []], ['1977', []], ['1978', []], ['1979', []], ['1980', []], ['1981', []], ['1982', []], ['1983', []], ['1984', []], ['1985', []], ['1986', []], ['1988', []], ['1989', []], ['1990', []], ['1991', []]]
Here's a subset of my FILMS list-
5042, 2985, 2985, 2985, 2985, 3021, 3021, 3021, 4095, 4095, 4095, 4095, 3604, 2020, 3930, 2004, 798, 798, 2584, 2593, 3825, 3825, 2618, 27027, 572, 798, 798, 798, 798, 1317, 1317, 1317, 3825, 890, 890, 798, 798, 3614, 1317, 1317]
I suspected it might be due to array data type U2 being wrong. Tried substituting with string equivalent S10. Did not work. I got an empty list for the Projects.
Will post the python code as a reply to the original question.
Thiru_P
Dan's method:
#import modules
import os
import arcpy
import numpy as np
#assign variables
fields = ['FLYING','FILM']
#create lists
Years = []
Films = []
YearFilmString = []
FilmList = []
    for row in cursor:
        filmString = row[1]
keys = sorted(list(set(Years)))
a = np.array(list(zip(Years, Films)), dtype = [('Years', '<i4'), ('Films', 'U2')])
out=[]
for i in keys:
    kv = [i]
    idx = np.where(a['Years'] == i)
    vals = a[idx]['Films']
    out.append(kv)
print out
close
you made years a string so the dtype should be 'U4' or its equivalent if using python 2.7.
Similarly your 'Films' is now a number and would need to be '<i4'.
If that isn't the case, post a list of the way that each is ie string or number
RandyBurton
for row in cursor:
    else:
print d
    print k
    print d[k]
1960
['A', 'G', 'J']
1972
1980
['C', 'E', 'F']
