Using Python to scrape points from a google map embedded on a website
5671
01-15-2020 06:36 AM
AliWertheim1
Hi everyone,
I am trying to use the requests library + beautiful soup to pull information on the antenna points from the map shown on this website.
BIPT: Sitebeheer
My original plan was to iterate through site numbers, pull out the lat/long information that appears on the left hand panel when a point is clicked, and display that data in Arc. So far I have accessed the <div> element where that information is located when the point is clicked (<div> id = selectedsite ... </div>). But the element turns up empty in python seemingly because nothing is clicked?
This is my first time web scraping and I have limited HTML knowlege, if there is another approach that would be better or any pointers you could offer that would be greatly appreciated
import requests
from bs4 import BeautifulSoup
#api_key = 'AIzaSyAv5Ru8AQCc9ZvfcrdYEg9SGHyDZqv55T0'
#Prettify HTML
source = requests.get("http://www.sites.bipt.be/").text
soup = BeautifulSoup(source, 'lxml')
print(soup.prettify())
# Class where information on the selected site is located - turns up empty
div = soup.find(id='selectedsite')
print(div.prettify())
DanPatterson_Retired
Are any esri products involved in the process? or is this a pure python question?
If the latter...
Stack Overflow - Where Developers Learn, Share, & Build Careers
might be a better venue
AliWertheim1
Thanks for this advice - I have cross posted on stack overflow as well.
BruceHarold
I can see a link to download a spreadsheet which exposes coordinates:
http://www.sites.bipt.be/lijst-liste.xlsx
I simplified it (attached, using Data Interoperability extension).
Then Convert Coordinate Notation tool can expose lat/long better:
